need 1978 pinto guage cluster
Date: 03/07/2021 07:35 am
Wanted early pinto
Date: 10/03/2019 02:42 pm
Date: 02/08/2018 02:26 pm
Date: 10/15/2017 10:03 am
1973 Pinto Wagon
Date: 05/06/2022 05:13 pm
Date: 03/17/2019 10:15 pm
Need Brakes for 1971 Pinto
Date: 04/27/2018 11:48 pm
door sills
Date: 03/14/2020 03:20 pm
Date: 08/26/2018 06:35 pm
  • Online today: 2,399
  • Guests: 1550
  • Total: 1550
52mm 3 Pod Gauge Cluster, Column Mount
Started by Pintopower, October 23, 2014, 02:38:15 PM
dianne
Vehicles:
- 1976 Mustang II mini-stock
- 1978 Mustang King Cobra II
- 1979 Ford Pinto Runabout
- 1986 Chevy K5 Blazer
- 1997 Suzuki Marauder
Pintopower
Quote from: dianne on February 06, 2016, 10:23:17 AM
I need this for my 79 :) Just bought a cheap one for now with 3 gauges.
My question is can you do a check engine light and fog on the other side? Need a check engine :)
Thanks,
Dianne
Yes I can do custom lenses for the 79-80 version for extra. Email me at pintopower@hotmail.com if you would like to know more.
#1. 1979 Wagon V6 Restored
#2. 1977 Wagon V6 Restored
#3. 1980 Sedan I4 Original
#5. 1980 Wagon I4 Restored
...Like i said, I like them.
...and I have 4 Fiats.
dianne
Thanks,
Dianne
Vehicles:
Pintopower
I know it has been a ton of time since I updated this but I wanted to show how they look installed and painted. I was waiting to get a good camera since I am tired of cell phone pictures. Well, without further ado:
The texture on the front was a result that I was counting on from the printing I chose. I am tired of glossy, cheap looking, warped and detail-less fiberglass so this is a welcome change
I also installed switch panels.
Over all I am thrilled at the outcome, functionality and aesthetics of the design. Everything fits perfect, looks like it belongs and not like an afterthought. I can see all the gauges and have now started on other upgrades for the rest of the fleet.
The turn signal variant is available here if anyone is interested:
https://www.shapeways.com/shops/ampro
It is in the "Ford Pinto" section. You will also need the lenses. I think I have already printed 30 of these for my other cars and all my friends lol.
76hotrodpinto
Cool, thanks for the follow up, and now to figure out how to pay -up...I really ,really need to budget for this gauge cluster..
Pintopower
Sorry to be a jerk and not post any links but I was waiting to get my parts in to make sure everything was correct and fit Properly.
I have and they do!
Main Enclosure for 1971-1978 Ford Pintos (79-80 will come soon, I need to remove the signals)
Signal Close Up:
Base, held on with large hose clamp
Inside area:
Close up of LED socket. These need a 5MM led to replace the turn signal. Please remember that the only way an LED will work on a 12V system is with a corresponding resistor to decrease current.
The enclosure can be purchased from here:
https://www.shapeways.com/product/QEDQAF3J3/ampro-gauge-cluster-w-signals
Signal Lenses here:
https://www.shapeways.com/product/EFJDD4F5G/ampro-gauge-cluster-signal-lenses
These will take a month to print and send over to you.
What ever you have heard about 3D printed parts being weak or substandard was only true a decade ago. Very soon, 3D printing will replace most forms of manufacturing. Trust me, I am in the industry and see it already.
email me at pintopower@hotmail.com for any questions.
What is shapeways ? These look great....
Pintopower
Ok, done.
These are being uploaded to shapeways now. The housing needs to be primer and painted to you liking (I recommend SEM interior paints) as well as the lenses. Lenses will work fine with fine coat of opaque paint. The signals are not bulb driven, rather LED. These are 5mm holes for a standard 5mm LED in a color of your choosing. Please note that most LEDs are not 12v so you will need to solder in resistors. I attached the wires to the dash turn signal bulb socket so as not to harm the printed board on the back of the dash. Please make sure your gauges will fit in the housing. This is attached with a clamp and will fit any 4" diameter steering column. Make sure you have adequate clearance between the column and the dash first.
Pintopower
Quote from: Pinturbo75 on January 07, 2015, 08:02:26 PM
I absolutely love that...... killer job.... !!!!
I have 2 earlier pintos.... and as mentioned it would cover the blinkers.... could you do some with the fan and fog light spots done up as turn signals????? id be interested in 2...
Yes, absolutely. That is the reason I haven't put them up for sale yet. I wanted to make turn signals for the early cars since from 1971-1978 cars have the turn signals in the middle. I will make the changes and put them up for production on shape ways. It is cheaper for me to sell them there than to actually have them molded. Plus the finish is great for painting.
Pintopower
Quote from: D.R.Ball on January 07, 2015, 02:45:56 PM
So when is the mass production to start? This by far the best way to mount gauges on the Pinto....So where can we get some....Hint....I do not want to cut up my dash or mount them where they are either in the way or are to far a way to be useful. For the older cars add turn signal/caution and hi beam and you have a deal.
I will make them available shortly!
entropy
Those turned out beautifully.  Still working on getting  my SW rig set up...when I do, I'll let you know!
1972 Hoonabout
SBF swap
-308 cid
-CNC ported Brodix heads
8" rear 4.11 posi
G-Force 5 Speed
10 point rollcage
Pintopower
Thank you! I Always felt that the Pinto needed some options for where to put the gauges. The track was a ball. I go rather often.
WOW, Glad someone made a Rally Pack for a pinto, Nice .  good photos of you car at the track and hope you passed a few , looks on their faces , Priceless  ;D
Pintopower
Quote from: russosborne on December 29, 2014, 11:15:55 PM
Holy Crap!
Those are EXCELLENT!
Thanks Russ. It was a lot of work but it came out better than I would have thought.
Quote from: Srt on December 30, 2014, 03:05:02 AM
that's some nice looking shizod there alberto.  kinda cool that you are also leading all those exotics around the course!
Well, I know it LOOKS like I was leading them...more like they were stuck behind me... I was taking it pretty slow on the straits as I really have no desire to hurt my car. That was where I would point everyone by. Funny thing was I had no one behind me on the curves. Man this car hooks up and the rear end breaks free so predictably.
Quote from: dga57 on December 30, 2014, 11:42:29 AM
Simply AMAZING!!!
Dwayne :)
Thank you Dwayne. Ill post better images after new years.
Pintopower
Well I wanted to post as I was building but I got busy. Everything was 3D printed, painted and installed. It came out better than I could have imagined. These parts come in a many colors but i like to start with white ABS and then paint them. I use SEM paint as the finish is better and stronger than anything I have ever used. The fascia was shot black and the housing was done in the burgundy to match the interior.
Lenses had the text bosses painted to match the cluster and the symbol bosses were also painted to match the cluster.
Wired up the warning lights. They looked nice. These are all LED. I don't do incandescent bulbs anywhere anymore. Too much current draw and too much damage to the dash housings.
I also made under dash panels for the switches and the volt meter. Also 3D printed in white abs with the text either being embossed (Rallye trim) or sunken so that I could make them glow like the factory lighting.
The LED's needed housings so those were made also and mounted to the rears. LED's provide the lighting.
Here are the gauges in the bezel from the rear. The posts simply provide rigidity, not that the bezel needs it. This think is rock solid.
Here is the text illuminated on the panel with the volt meter. I made this out of a simple LED display. Tiny and effective.
Here is the other side:
Here is the harness I made for the gauges and the switch panel. Common ground, separate circuit for "On", "On/AUX" and constant. Not a single factory wire in the car was cut or damaged. Adapters were made to prevent that.
Once installed and tested, this is what we have:
This image is terrible. The lighting looks far brighter than it is and the colors are all off. The red hue is identical everywhere with matching intensity and the night time brightness is great. The column gauges are a dream come true. They look factory and match the car, unlike how the car used to look with gauges strewn about haphazardly.
The number driven digital tach is horrible as usual but it is the led boarder that it has that works like an analog unit and looks fabulous. I am sold. Ill take better pictures of the interior soon. I was to busy getting the car ready for the track day my wife and I went to:
I think I was the only car there with a working heater and air conditioning. Man, I love this car.
Oh here is another project I have been working on:
I just printed 20 of these out and sold them to  my friend before I could even keep any! They are so much better than the stock ones. Stronger and the light cast is no longer a medium brown from the old junky one.
Overall, I am thrilled with the looks and functionality of the interior. Not to mention the cost! It was CHEAP! Who says 3D printing is expensive? everything was under $100 including the panels and the lenses. The fiberglass and plastic stuff I have bought in the past was way more expensive and never matched the car. With 3D printing, I can make everything perfect with a tolerance down to 0.1mm! try that at a machine shop and see what they charge you. I cant wait until I can print my Rallye front and rear spoilers. Big stuff is still pricey but give it time.
Ill post better images soon!
Have a happy new year!
Pintopower
Quote from: entropy on December 19, 2014, 09:37:46 PM
Nice design!  I'm learning Solidworks and if you'd be interested in collaborating, I'd be into helping.
Gladly! I am always down to collaborate and not need to reinvent the wheel. Creo can read SW files and save them back out as SW so that could work!
entropy
1972 Hoonabout
SBF swap
-308 cid
8" rear 4.11 posi
G-Force 5 Speed
10 point rollcage
Pintopower
I forgot to mention why the lenses are embossed like that. I am going for the 79-80 Pinto style where there us text in white on the idiot lights with a matching symbol by it. The symbol is green. I am just trying to make everything match as well as I can.
Pintopower
Well Jeez, so many replies and no pictures? Come on guys! Let's see where you have placed them in more detail. Might give me an idea to steal and call my own.  8)
I have seen that a few time Scott but I have later cars with ac and consoles and all sorts of goodies so sadly I have no room there. I am trying to go for a "How Ford would have done it" without the falling apart and crumbly, blue cheese like plastic that they gave us on so many plastic bits.
I have since updated my look for my '79. I discovered that I was going down thw wrong path. If this was on the column, it has to look like it matches. So I took other styling clues and applied it to the cluster. Here we are so far:
The beauty of 3D printing is that detail does not cost more. Oh, you might be wondering how much this will be. Right now, printed, out the door, $60. This is not including the little lenses and the simple version of this will be in the $55 area. Man, I spent like $80 on my a-column gauge set. This basically means I can have anything for the pinto 3D printed once I have it scanned. Yup, grilles, hot pants kit, air dams, valences, gauge housings, you name it. Plus, in most cases we are talking about less costly than conventional methods and infinitely more accurate. I love technology.
Scott Hamilton
Alberto,
Very, very interesting... I would really like to see your installation. I have mine mounted below the radio.. Looking down is ok for me at this time but I wanted at some point to put in a tach... This sounds very interesting. Knowing you- it will look great!
For my 71 half hatch I bought the retro Sun 802R tach that comes with a chrome gauge cup to go on my steering column flanked by my vintage (1975) 2 5/8" Sun blue line oil & water gauges in matching chrome cups. The matching blue line volt & vacuum gauges will go in a vintage chrome mount under the dash. I have a very specific mid 70's look I'm going for & chrome cups & a worm clamp are the only way to go.
