Date: 01/06/2017 11:42 pm
1977 pinto rear bumper
Date: 04/19/2021 11:57 am
Front sway bar frame brackets
Date: 07/13/2017 01:05 am
Date: 05/13/2021 05:29 pm
Date: 05/22/2018 01:54 pm
Date: 06/19/2018 03:58 pm
Needed, 2.0 or 2.3 motors
Date: 09/30/2018 07:47 pm
Date: 08/22/2017 09:21 pm
77 pinto
Date: 08/22/2017 06:31 pm
  • Online today: 2,670
  • Guests: 540
  • Total: 540
Found the issue
Started by Greymare, October 18, 2014, 10:46:10 PM
Greymare
Well I was planning on using my intake and exhaust. I guess I will have to take a look at the intake ports. I know for a fact that it has a hole for the distributor. Any thing else?
Clydesdale80
are you planning on putting your carb on it or using the EFI? If you're getting rid of the injection and computer then you'll need to figure something else out for ignition because I don't believe those engines have a hole for a distributor.  I also think the intake ports are different shaped.
Bought a 1978 hatchback to be my first car.
Greymare
Well I started working on the wagon today and was hoping to be able to only change the belt. I pulled the timing cover and was going to spin the cam to put in time. It wouldn't move so rather than force it I pulled the valve cover. Well much to my surprise the cam from 3-4 was covered in some amazing rust! I am not talking surface rust. This was some crazy rust to the point it had white crystals forming from out of the cam bearing towers. I am not sure how this happened so I pulled the head and went on a search for a head. I have been offered a engine from a 1987 Ranger 4 plug head injected 2.3L with a blown head gasket for free!
1) Will this engine work in my 76 wagon?
2) Will my intake, exhaust, and AC bolt up?
3) any surprises I might run into?
Thanks in advance for any help.
