Date: 12/31/2017 11:14 pm
73 Runabout
Date: 11/20/2017 03:19 pm
Date: 08/05/2018 01:58 pm
Mirror
Date: 04/15/2020 01:42 pm
1977 pinto rear bumper
Date: 04/19/2021 11:57 am
73 rear hatchback glass
Date: 07/06/2017 11:33 am
Need 2.3 timing cover
Date: 08/10/2018 11:41 am
postal pinto
Date: 06/03/2020 09:31 am
2 Station Wagons for sale
Date: 04/20/2018 11:10 am
  • Online today: 481
  • Guests: 368
  • Total: 368
DOORS
Started by PINTOOOOO, September 23, 2014, 07:28:23 AM
Some people claim that you can swap the upper channel to use any door on any car but your welding & measuring skills better be spot on to get that right.
The reason the wagon doors won't fit is because the window frame is different. On the wagon the back end of the window frame runs straighter to to follow the roof line where as on the sedan it curves downward. It MIGHT be that in a pinch a sedan door would possibly fit a wagon, but if it even did there would be a gap in the rearward corner where the sedan door curves downward.
PINTOOOOO
THANK YOU FOR THE HELP
Wagon doors are wagon ONLY. Any year sedan door will fit a 73 but 74-up doors need the 74-up upper hinge. The lower is the same but the upper hinge on early doors has less distance between the 2 bolts.
PINTOOOOO
WILL WAGON DOORS FIT ON A SEDAN .WHAT YEARS WILL FIT ON A 1973
