77 Cruising Wagon Front Seats
Date: 04/12/2017 12:37 pm
Mustang II V8 swap parts
Date: 03/26/2017 02:25 pm
Date: 07/10/2016 10:17 am
Date: 12/31/2017 11:14 pm
V8 rear end
Date: 04/12/2018 10:57 am
Date: 07/13/2018 02:21 pm
Date: 02/18/2017 05:55 pm
Date: 08/05/2018 01:58 pm
  • Online today: 445
  • Guests: 406
  • Total: 406
Clutch cable removal
Started by HiPopinto, September 13, 2014, 07:51:41 PM
Quote from: Reeves1 on September 16, 2014, 04:29:41 PM
What year ?
Looking for clutch / brake peddles for a 72....
He snuck "80 coupe" in there. I read it 3 times before I saw it
Quote from: HiPopinto on September 13, 2014, 07:51:41 PM
Hey all
I swapped my 5 speed out for a reverse manual shift C4
I can't figure out how to get the clutch cable out!
Lathe clutch Pedal is removed but I would like the cable out as well to clean up the engine bay
Any Input would be awesome
It looks as if it pushes Into the firewall
I can't figure how to get it out though
It's a 1980 coupe
Thanks guys
Dave
What year ?
Quote from: dick1172762 on September 15, 2014, 07:51:37 PM
I'll have to try that one! Sounds even easyer than a clamp.
I came up with the socket idea when I tried to do the clamp on my 80 with the interior still in & all the wiring in my way. I couldn't get both hands up in there to work so I tried a box end wrench which I couldn't get in there & finally a 6 point socket which was perfect. Chalk my discovery up to utter frustration & old age LOL
Even easier than a clamp is to slide a deep well socket (9/16 I think) over the end under the dash. Push it on till it hits the firewall then go pull the cable right out.
Slip a small hose clamp over the cable on the inside of the car. Put the clamp over the barbs next to the firewall and snug it down enough so you can push the cable thru the hole in the fire wall a little bit. Then loosen the hose clamp and push the cable on thru the firewall. Easy to do.
HiPopinto
Hey all
It's a 1980 coupe
Thanks guys
Dave
