Wheel cap
Date: 04/25/2022 11:21 pm
Early 2.0 engines
Date: 05/09/2018 12:45 pm
1977 Pinto Cruizin Wagon
Date: 08/07/2023 02:52 pm
PINTO TRUNK LATCH & CATCH
Date: 03/23/2018 09:39 pm
6.6.75 carrier
Date: 02/14/2018 06:47 am
Date: 06/05/2018 09:13 pm
Early 2.0 engines
Date: 01/18/2017 05:35 pm
Date: 11/08/2019 10:01 am
  • Online today: 502
  • Guests: 500
  • Total: 500
Where on the 2.3 block would I find the part number?
Started by russosborne, August 24, 2014, 05:11:12 PM
Thanks.
My block has a D8 part number. That would make it a 78? This is really confusing to me. Maybe I don't understand the Ford part numbering system as well as I thought.
I'll  look for the partial vin just to see what it has.
My E3ZE block has the casting number at the top rear passenger side.
There is a machined pad below the "CTP" out of frame where a partial VIN from the original car is stamped.
upkingpin
MY 78 part # is on passenger side of block at top adjacent to cyl. #1.  have seen an 86 mustang in same place.  hope this helps.
thanks.
I am hoping to find the casting number on the block itself though.
The D4 head is a 74 casting number with oval ports & a heart shaped combustion chamber.
The E1 is an 81 casting & most probably a D port carb intake that was made for 2.3's from 81 to 83.
Sorry, another goofy question. :-[
For some reason I am OCD'ing about this engine and wanting to know for sure what it came from. I am thinking it is an 86 Mustang, but not sure. :-\
The intake, exhaust (cast iron header), and the bell housing are all Mustang parts, the intake is an E1Z, the other 2 are E6Z. It did not come with a carb or anything else on the intake.
The head has a D4 code, but apparently that code was used on many years, if what I have found online is correct. I haven't yet taken the intake off to see what style the intake ports are.
There is always a chance that these parts were not original to the engine, which is why I am wanting to see what the block code says. I've done a quick look but haven't found anything.
Thanks,
