Hatch needed
Date: 09/10/2017 09:16 pm
1976 pinto for sale
Date: 01/12/2017 02:08 pm
1978 Squire wagon 6 Cly
Date: 03/08/2021 10:44 am
Date: 09/02/2021 08:21 am
looking for parts
Date: 06/19/2020 02:32 pm
Date: 08/03/2018 09:19 am
2.8 radiator
Date: 10/25/2019 04:10 pm
Date: 11/12/2020 08:28 pm
Date: 02/21/2017 06:29 am
  • Online today: 600
  • Guests: 358
  • Total: 358
Rotor swap
Started by Pintocrazed, August 09, 2014, 02:12:37 PM
I didn't take a micrometer to them but I've had early & late rotors side by side & the vents appear similar in size. Cutting late rotors down to work on an early car should leave plenty of material.
Quote from: oldkayaker on August 10, 2014, 06:24:47 AM
I believe the "hub reg" refers to OD of the rotor hub where the factory steel wheels center themselves on the rotor.  I do know that the early factory steel wheels will not fit over the larger later year rotor hubs.
If that's the case, then turning the hub diameter down to the early size wouldn't be hard. Pretty common with Granada brake swaps going onto early Mustangs.
QuoteAs far as machining a later year rotor down, I would have a concern with the later rotor "min thick" being larger that the early rotor "nom thick".
That's a definite consideration if the vent passages are wider in the later rotor....and they probably are to save weight and material.
Since you are considering non-stock set up, this link shows how to install larger 5 lug rotors on the early spindle plus some other custom ideas.  Note, larger rotors usually require larger wheels.
http://www.fordpinto.com/pinto-faq/front-disc-brakes-(4-5-lug)/msg6498/#msg6498
I was thinking that it might be fairly trivial to machine the 74+ rotors, but I have access to a machine shop.  8) Not everyone does.
Do you live near a self service yard? The local Pick Your Part has rotors listed at $14.99 with a $3 core charge.  Probably $20 each out the door.  On the 50% off sale day about $13 each.  I know there aren't Pinto's every trip, but man, maybe I should be grabbing them when I can. If they Mic OK and aren't deeply grooved they are probably good.  For the record I did get a spare set a number of years ago because people were complaining they were $100 each.  Now $150!
Which brings up the subject..., can your rotors be turned? I think Pep Boys charged about $13 a rotor when I had my wife's Civic rotors turned.  I opted to have them turned figuring the warping had run its cycle. I felt new rotors would just warp again.  So far 9 months later everything is good.
What does the "hub reg" dimension refer to?
See bbobcat75's link for the differences in the rotors.  Rockauto is a little cheaper at $222 plus shipping for two ACDELCO 73 rotors.  Maybe put an ad in the wanted section.  Good luck.
http://www.fordpinto.com/pinto-faq/71-spindle-to-74-spindle/msg130024/#msg130024
Pintocrazed
:( I didn't want to spend 300 for rotors
Plain and simple, NO.
Pintocrazed
Anybody know if I can use 74 up rotors on my 73?the 73 rotors are crazy expensive
