1973 Pinto hatchback for sale
Date: 11/13/2023 11:30 am
Date: 02/18/2017 04:47 pm
1976 Ford Pinto Pony
Date: 09/06/2018 05:40 pm
Date: 10/24/2018 07:35 am
KYB shocks
Date: 02/08/2017 07:09 pm
Need seals Pinto Wagon
Date: 02/16/2017 05:09 pm
1980 Pinto for sale
Date: 11/24/2016 06:32 pm
1979 PINTO PARTS--FREE
Date: 09/13/2022 02:05 pm
74 & Up Parts
Date: 01/20/2021 03:22 pm
  • Online today: 548
  • Guests: 423
  • Total: 423
I made my car quieter
Started by JoeBob, July 31, 2014, 09:56:14 PM
Is it the foam that gets wet, or is it that the foam just holds the water in place instead of letting it drain properly?
I am wondering becuase I have seen some foams that claim to be waterproof.
Just curious, no plans on using the stuff.
Thanks,
dianne
Just my 2 cents and recommendation. I would remove the panels and then take out that expanding foam before it gets wet and starts rusting. That is a great way to quite the car and then later get rear quarters to replace your rusted ones. Seen it on cars I looked at before, and it rusts it badly.
There are some inexpensive mats you can get (other than dyno mat or something).
Vehicles:
- 1976 Mustang II mini-stock
- 1978 Mustang King Cobra II
- 1979 Ford Pinto Runabout
- 1986 Chevy K5 Blazer
- 1997 Suzuki Marauder
Quote from: bbobcat75 on August 01, 2014, 07:11:21 AM
the only thing I see that may cause a issue is that foam and peanuts are like a sponge and will hold - water/moister - i would have used a sheet dynomat for the noise  first personally.  just my 2 cents
My thoughts exactly. You could also use a can of spray truck bedliner on the metal. A couple coats will deaden sound & protect bare steel. I do this inside my doors & under fenders too.
I've seen that before .....and it causes rust through quickly.
bbobcat75
1975 mercury bobcat 2.8 auto
JoeBob
I decided to try to make my car quieter. If you notice in the hatch back there is an access panel to replace the light bulbs on the marker lights. This gives you access to the hollow back fenders. These hollow fenders amplify road noise like a drum. I decided to fill this area with expanding insulation foam. I removed the plastic panels then I took a paper cup, cut the bottom out. This will make a tunnel to the marker bulb, so the foam would not prevent access. I has been some years since I bought this foam. It does not expand to fill the void like it use to. One can would expand 2-3 times its size over a few minutes. I was unable to find any expanding foam. The stuff now stays the same size that you spray out. It would have taken 5 or 6 cans to do the job each side. So I filled the area with a combination packing peanuts and the foam to form a solid fill. Now my car is much quieter. I hope this works for you.
77 yellow Bobcat hatchback
Deuteronomy 7:9
