1978 Squire wagon 6 Cly
Date: 03/08/2021 10:44 am
Date: 05/03/2024 05:37 am
Pinto hubcap
Date: 01/07/2017 08:40 pm
1974 Pinto Door Handles
Date: 03/07/2017 04:06 pm
Front Body parts needed
Date: 02/09/2018 06:09 pm
71-73 Front Kick Panels
Date: 04/25/2021 07:24 pm
78 hatchback
Date: 03/12/2023 06:50 pm
Beautiful 1980 Pinto
Date: 04/13/2020 11:53 am
Date: 03/21/2017 07:47 pm
  • Online today: 481
  • Guests: 140
  • Total: 140
ford 2.3 issues...stumped and need help with this motor please!
Started by Basher13, July 29, 2014, 12:06:39 AM
tbucketjack
72pair
Hold at half throttle and see if fuel is siphoning out of the accelerator pump squirter. Had this problem before with the 500. If so, a heavier check valve under the pump squirter will help. Holley makes an anti=pullover squirter also. I had luck using long tube squirts with the heaviest check I had...had a stainless one from an alcohol kit.
rramjet
How about distributor cap, points, condenser, rotor. Might have spark  jumping. Look for carbon tracks in/on cap. What does a timing light show? Timing mark nice and steady?
Basher13
I have a ford 2.3 in a dirt track car.  It has a comp cam, double springs, anti pump lifters, adjustable cam gears, holley 500 carb, carter marine aftermarket electric fuel pump, accell hi voltage coil. stock points distributor, race gas used.
Here is the problem......the motor idles fine.  when you take it up to about half throttle and hold it there it develops a bad miss.  same things happens in gear.  can idle or rev high and its smooth.  Hold the throttle and it misses in gear or out of gear.
what I have tried....new plugs, new wires, adjusted distributor for timing issues, no vacuum leaks that I can tell, new gas, tried 2 different Holley 500 and did the same thing.
Any ideas on what could be the problem?
