Date: 11/14/2019 04:02 am
Date: 10/04/2019 08:43 pm
Date: 05/21/2019 11:50 am
Date: 02/28/2024 02:07 pm
PINTO TRUNK LATCH & CATCH
Date: 03/23/2018 09:39 pm
74 & Up Parts
Date: 01/20/2021 03:22 pm
1980 Pinto w/ Trunk
Date: 08/10/2022 04:09 pm
77 pinto
Date: 08/22/2017 06:31 pm
Various Pinto stuff for sale.
Date: 11/21/2018 01:56 pm
  • Online today: 905
  • Guests: 401
  • Total: 401
Pinto Problems
Started by Pinto Loser, September 22, 2003, 01:09:24 PM
your both right.  Hot climate, it will overheat.  Cold climate, not enough heat.   Use a thermostat!
straw boss
Actually, I think the opposite would happen.  Your engine would never warm up!  I have never tried this personally, however.  What a lot of people don't realize is the water pump impeller is more efficient when operating with "head pressure".  If you remove the thermostat, you will remove the major flow restriction in the cooling system, and the pump will operate without any significant head pressure.  This becomes a problem when you rev up the motor, because the pump will start to "cavitate".  Cavitating is when air bubbles form on the trailing edge of the impellers, reducing the efficiency of the pump.
In other words, don't remove the thermostat!
A word about Tstats. DO NOT REMOVE IT. replace it with the correct type. A car without aTstat will most likly overheat becouse there is not enough restriction to SLOW the water down long enough to the the radiator to displace the heat. OIL leak, could be your oil pan, oil filter, valve cover, cam seal ( this one is hard to chase down), rear main seal, transmission. etc. clean it up and start ruling things out.
79Minto
Well You Should replace the Thermostat. To find the leak  you could wash the engine then next morning look to see where the oil is coming from.
Pinto Loser
I have a 1976 Pinto Wagon. It runs well but there is a problem with the thermostat sticking. Should I get a new one and replace it or should I just take it out and leave it out? Also there is an oil leak where is the most likely place it would be leaking and how costly is it to fix it? ???
