2.3 pinto carb
Date: 08/18/2018 02:07 pm
Wanted hood hinges
Date: 02/17/2020 05:30 pm
Date: 02/08/2018 02:26 pm
FREE PARTS!!
Date: 01/10/2017 02:38 pm
1974 Ford Pinto Runabout
Date: 07/10/2025 09:33 pm
Pinto or Bobcat wagon wanted
Date: 08/05/2018 10:49 pm
99' 2.5l lima cylinder head
Date: 01/13/2017 01:56 am
Date: 03/06/2019 06:40 pm
SEARCHING HOPELESSLY
Date: 02/02/2017 07:21 am
  • Online today: 210
  • Guests: 185
  • Total: 185
HELP HELP PINTO IGNITION SWITCH FITTING
Started by cannonball, July 23, 2014, 02:51:50 PM
Under certain freaky circumstances involving a very low battery about to die the solenoid can snap shut to then weld itself shut and do that too. Solenoid then may be bad but not the ultimate problem, which will be the battery.
dennisofaz
Hi Cannonball,
You might want to disconnect the solenoid trigger wire at the solenoid.  If it still turns over then it is a bad solenoid, if it stops turning over then it is a bad switch.
Dennis[size=78%] [/size]
cannonball
HI GUYS
I AM RACING MY PINTO ON FRIDAY BUT THE IGNITION SWITCH IS STUCK OR GONE CRAZY THE STARTER MTR TURNS OVER EVEN WHEN THE MTR IS RUNNING IT WILL NOT SHUT OFF TILL I KILL THE BATTERY IF I HOOK THE BATTERY BACK ON IT WINDS OVER STRAIGHT AWAY AND STARTS UP WITHOUT THE KEY TURNED, I HAVE A NEW SWITCH TO FIT THE ELECTRICAL BIT NOT THE KEY BARREL HOW QUICK AND SIMPLE PROCEDURE TO FIT IT IS THE SLIDER SWITCH WITH THE MULTI PLUG ON THE END, I SUSPECTED IT WAS FAULTY AS I ONCE GOT A PUFF OF SMOKE OUT THE STEEERING COLUMN NEED TO DO THIS RAPIDO TOMORROW ALL INFO GRATEFULLY TAKEN,,,,,,,,,,,,,,,,
