Date: 03/05/2017 03:27 pm
1971-74 Various Pinto Parts
Date: 01/18/2020 03:44 pm
Looking for a 1980 windshield
Date: 07/30/2020 04:51 pm
Date: 04/06/2017 12:13 am
1980 hood needed
Date: 04/23/2020 10:41 pm
NOS Sedan decklid
Date: 10/23/2019 11:51 am
Date: 12/09/2018 06:59 am
1971 Pinto Parting out
Date: 07/06/2018 01:11 pm
Date: 07/01/2019 03:17 pm
  • Online today: 548
  • Guests: 292
  • Total: 292
Pinto engine not turning over
Started by mcboyle, July 17, 2014, 04:51:03 PM
Hope it's good and WATERPROOF.........................had one installed and worked fine till one night about 3 in the morning was accelerating up to speed on freeway entrance ramp and all of a sudden the most Godawful racket you ever heard, the switch had shorted to make starter come on at high engine speed. Dunno how I didn't tear the starter/bell housing up. In the middle of summer and no rain for a month, switch was bone dry inside but also had heavy evidence of water getting inside to corrode parts massively. And the switch was chosen because it WAS waterproof so I dunno...........
mcboyle
found it! they had a little button installed to actually start the engine inside the hood to use while working on the engine. simple cable got disconnected. that was easy.
1974 Pinto Station Wagon
Might wanna look at what the shop did and what area they were in if the problem showed up as soon as work got done.
As stated above, grounds first and then move to solenoid, and/or starter. That's about it under the hood. Only other thing I can think of would be the ignition switch at the base of the steering column, but unlikely.
Check all battery, starter & solenoid connections 1st to see if something is loose.
mcboyle
This particular one is a 4 speed :/.
what tranny.... auto maybe not fully in park????
mcboyle
I just got the Pinto back from the shop all ready to drive it. I had a coolant leak taken care of and everything looks fine with that now. But once i got it home i parked. let it sit for a bit to just check up on this after driving. I tried to start it again and nothing happened. nothing but a held out beep that seems to be coming from the dash, and all the lights light up {check engine, alternator, brake etc) but absolutely no sound from the engine at all. not whining, no clicking. nothing. Im thinking its a pretty easy fix like something is just disconnected but i can't seem to find the problem anywhere. does anyone have any suggestions on some things that could be causing this problem?
