Date: 02/14/2018 01:34 am
Pinto Runabout wanted
Date: 06/05/2018 04:42 pm
1980 Pinto w/ Trunk
Date: 08/10/2022 04:09 pm
1978 Squire wagon 6 Cly
Date: 03/08/2021 10:44 am
Date: 08/17/2022 06:27 pm
Seeking parts
Date: 10/18/2020 10:35 am
Pinto Wagon
Date: 05/25/2018 01:50 pm
Date: 04/06/2017 12:13 am
Date: 09/01/2017 07:52 am
  • Online today: 525
  • Guests: 206
  • Total: 206
Manual 4-speed 74WT Toploader Transmission: What type of oil should I use?
Started by Cormac417, July 17, 2014, 12:56:39 PM
ToniJ1960
 I got a rebuilt transmission for my 78 6 or 7 year ago,all I used was pennzoil 90w I think they sell a type for hypoid gears. I know the gears in the transmission arent straight cut thats why ou cant shift too well without a clutch like some other cars. So I would assume the hypoid gear lube would be good. My transmission is still perfect and so quiet :)
If you go to GL-5 which automatically has slip additive in it like for Positrac limited slip units it would probably be even smoother and the synchro brake surface would not wear as fast............
Quote from: Starliner on July 19, 2014, 09:34:31 AM
Redline MT-90 75W-90 GL4 will protect your synchros.
it will also smooth out your shifting.
You can buy it from Summit Racing online.
RED LINE IS THE OIL TO USE BAR NONE.
Starliner
1973 Pinto 1600 - Sold!
1979 Pinto 2300 - Sold!
PintoMan1
1973 pinto runabout
Cormac417
What type of oil should I use to change the gear oil in a 1975 manual 4-speed 74WT top-loader transmission?
Phill
