Tire needed p185/80r13
Date: 12/31/2017 09:08 pm
Date: 07/08/2022 11:51 pm
1972 Rallye wagon rebuild
Date: 11/14/2020 07:31 pm
pinto parts for sale
Date: 07/25/2018 04:51 pm
1979 PINTO PARTS--FREE
Date: 09/13/2022 02:05 pm
Date: 01/19/2021 03:56 pm
Date: 01/23/2017 07:41 am
Date: 12/04/2018 07:40 pm
Date: 03/23/2018 09:23 pm
  • Online today: 394
  • Guests: 355
  • Total: 355
74 with electrical shutdown
Started by righthandman, July 09, 2014, 02:25:42 AM
Check for a loose plate that the points bolt to. Had that happen more than once.
I do not remember the exact wires from the seat belt interlock module but two of them cut and twisted together bypasses the whole mess. Had a car that mysteriously slowly ran the battery down over and over until I found it in that module.
Have you tried resetting the seat belt/starter interlock?  There's a red button in the engine compartment that does that.  Can't remember its exact location (it's been 38 years since I last owned a '74 Pinto) but it's not hard to find.
Dwayne :)
righthandman
 Yea guys this is point type ignition. Was electronic available in 74?
What about this seatbelt safety switch. Fords better idea for "74". Is that something that shuts off power to the ignition coil or to the starter so the cars engine won't crank over?
I have had the opportunity to check for spark on occasion and found none, but yet the car will restart sometimes instantly other times an hour later. Without me doing anything at all.
Any ideas. Please run them by me caus I can't stand to be embarrassed by a car as simple as these old ones.
        Thanks,
Condenser says not electronic ignition...............
If you get to one of those 'let it sit before it starts' days you should be checking for spark right then. You WILL have to get under hood to solve the issue. Can be literally 50 things although mostly a small handful.
slowride
Same issue and symptoms as my 74 had. New ignition module (on fenderwell) and no failures in 3 years.
Those intermittent problems are hard to track down until they permanently fail.  Do not rule out the fuel system, a dying fuel pump, dirty fuel filter/sock, and/or a fuel tank vent problem may give similar effects.  If it is electrical, I would first suspect the ignition switch.
righthandman
 I have this 74 with a 2.3 that every once in a great while it will just shut off. It sometimes will start right back up and run as good as ever and other times it will have to sit for a few minutes, but always has started back up without doing anything under the hood. and it always runs great when its running.
I put a new coil on, and then a new condenser, but now I am stumped.
Any ideas greatly appreciated.
