1977 pinto rear bumper
Date: 04/19/2021 11:57 am
Date: 04/07/2021 06:12 pm
78 windshield trim
Date: 02/01/2020 08:46 am
72 Pinto
Date: 03/07/2019 12:07 pm
Pinto Wagon
Date: 05/25/2018 01:50 pm
Cruiser Dash Gauges
Date: 12/04/2016 11:50 am
Interior Parts
Date: 08/07/2017 03:59 pm
1980 Pinto Parts
Date: 08/05/2020 04:20 pm
74 Pinto Rear Side Lights
Date: 02/18/2017 05:47 pm
  • Online today: 529
  • Guests: 373
  • Total: 373
Rot
Started by dedinski, July 08, 2014, 05:35:07 PM
Depends on how much is compromised. Flat area easily patched, it's when you start losing bends, folds, angle and plane changes and corrugation that you really begin losing strength. Unibody strength comes from the way the material is reinforced by that, not the material itself. You can actually put holes in flat planes and not lose much doing it.
dedinski
Yipes. Probably need to patch it then hmmm
Just remember, that inter fender panel is what helps hold the front end of a Pinto up.
dedinski
Cool thanks AMC
If still enough material left you can bolt down an aftermarket steel battery tray, I even altered mine to narrow it a bit to give header some room to not melt things.
chrisf1219
depends on how bad it looks.pm pintopower he has custom battery hold downs and brackets along with some stock ones I think? hes name is alberto he is located in san jose . I will check it out when you come over to my house. chris
dedinski
Cool thanks for the reply. Any fixes that you know of?
VERY COMMON. Somewhere around 50% that I've seen or owned.
dedinski
So is rot under the battery area of the car common? So new to all this but it would be good to know =)
