Date: 08/05/2018 01:58 pm
Pinto Watch
Date: 06/22/2019 07:16 pm
1973 Pangra
Date: 01/06/2015 02:19 pm
1973 Pinto Wagon
Date: 05/06/2022 05:13 pm
Wanted early pinto
Date: 10/03/2019 02:42 pm
Date: 09/17/2024 12:35 pm
ford pinto door panels
Date: 03/20/2022 07:51 pm
Date: 01/19/2021 03:56 pm
parts needed
Date: 02/20/2017 07:58 am
  • Online today: 367
  • Guests: 151
  • Total: 151
Lower ball joint help needed
Started by lightning, July 06, 2014, 05:08:17 PM
lightning
Yup. Bolts just started. Top flange downside up in pic. Fixed it. Thanx for the reply.
Using Tapatalk
Could easily be, hoping the bottom flange is showing simply because you have barely threaded bolts on so far. Bottom has to be pulled up inside where we can't see it.
lightning
Using Tapatalk
'... replaced lower BJ with uppers.'
Whoa I totally misread that one, thought you meant all 4 got changed. My bad.
Can't get much more bubba than that............
lightning
The pin taper and length is diff. I had a "rattle" in the front end because it wasn't tight. 2 of the bolt holes lined up (enough for Bubba). ;(
Using Tapatalk
If bolted on top nothing holds the rubber seal down..........................
enzo
WOW. Not sure that is even possible.  Not sure if the pin taper is the same on both, as well the length and diameter!
Then there is the fact that the top b/j has 3 bolts the same size of each other, and, the lower has 4 bolts - 2 different
size of the other 2.  Has the lower control arm been modified?, cut?, and rewelded?  But, to answer your original
question, from the bottom.
lightning
My 78 wagon is a REAL bubba special. Bubba replaced lower BJ with uppers. Do the lowers go up through the arm or bolt on top?
Thx in advance.
Using Tapatalk
