Date: 08/16/2018 08:54 am
Date: 02/05/2020 11:06 am
Date: 09/12/2018 12:33 pm
Date: 07/11/2023 11:39 pm
Seeking parts
Date: 10/18/2020 10:35 am
Mustang II V8 swap parts
Date: 03/26/2017 02:25 pm
71-71 speedo cable
Date: 07/31/2021 09:04 pm
1977 Pinto for parts
Date: 10/10/2018 06:25 pm
Date: 10/03/2018 02:00 pm
  • Online today: 367
  • Guests: 189
  • Total: 189
alt bracket
Started by chrisf1219, July 01, 2014, 02:31:53 PM
82expghost
i used a smog pump bracket and drilled it and tapped it to fit the alternator, then two heims joints bolted it to the alt and a empty bolt hole on the front of the block, used a pipe i found as spacers to move alt inline with pullys
98 taurtus, now in heaven
77 pinto, weekend warrior
92 grand marquis, daily
All you need is the factory ac bracket / mount off of any 2.3L Merkur to mount the alternator on the pass side. Pass it on to the Mustang people.
Scroll down some for a custom bracket photo.  Down a little further is a Ranger bracket.
http://mustangforums.com/forum/svo-forum/535411-alternator-placemant-issues.html
Scroll down for another custom bracket.
http://forums.vintage-mustang.com/vintage-mustang-gallery/611035-beaus-68-coupe-11.html
Probably easiest to cruse the junk yard for something.  From readings, the pulley spacing front to back varies between applications.  So if you find something at the JY, probably best to get all brackets and pulleys.  Hopefully somebody who has done this will chime in.
Probably didn't have anything else hanging on that side??..
Just saw a picture of a 2300 in a Ranger and the alternator was on the passenger side. How about that? Don't know what year.
IF, I could just get a little free time I plan on moving mine over, if there's nothing hanging on the passenger side now it's a no brainer, looks like you could use the same belt too?,  piece of flat stock from the scrap, er I mean the material bin bent on each end for the mount, a flat alternator adjuster from whatever as long as it's long enough, I have one from a Chevy(I think) just have to cut it to length, couple spacers and done deal, extend the wires of course and you're good to go.... Now if there's other stuff hanging on the right side then that's another story,lol..
Odds of using same belt are 1,000,000/1.
chrisf1219
hi this was probally posted already but I will ask again.i have a 77 2.3 with power steering and want to move alt over on the pass side.what kind of mount can be used?also will I need different size belts? I run twin belts on mine. thanks for any and all help.  chris
