Date: 08/13/2021 10:39 am
72 Runabout Sprint Edition
Date: 04/25/2018 02:51 pm
Date: 04/21/2017 02:03 pm
Date: 11/05/2020 06:32 pm
1977 Pinto Hatchback Parts
Date: 08/29/2020 05:31 pm
Pinto Runabout wanted
Date: 06/05/2018 04:42 pm
oldskool787
Date: 02/12/2017 12:42 pm
Date: 02/22/2017 01:58 pm
78 pinto wagon
Date: 06/04/2020 12:42 pm
  • Online today: 367
  • Guests: 171
  • Total: 171
2.5 Liter Intake Concerns
Started by 80_2.3_ESS, June 26, 2014, 10:12:50 AM
80_2.3_ESS
Quote from: 65ShelbyClone on June 27, 2014, 06:06:55 PM
Wait, it has an actual d-port head, or it has the original 2.5 head?
The '98-01 Ranger 2.5 uses a completely different intake. Nevermind port mismatch; the bolt pattern is different too.
Not 100% sure what the head came off. The ports were D shaped and the Offenhauser intake matched right up. The head has hydraulic lifters too.
Nick in CT
1980 2.3L Pinto ESS
Quote from: 80_2.3_ESS on June 26, 2014, 10:12:50 AM
The motor is a 2.5 Liter from a Ranger with ...... "D" intake ports.
tbucketjack
You might be able to build a step up in the manifold with JB Weld and using a gasket as a template and form. Just an idea if you're creative and have the time. Good Luck
You pretty much hit the nail on the head with the resolution there. I would say run it like that but the bottom blocked and then part of the middle by way of the divider and more than just the bottom then. If the port was open with no manifold divider it'll run, just top end power will be down a bit.
D.R.Ball
Try esslinger they are the 2.3 and 2.5 N.A. guy's if they you do not know about you do not need to do it. On a 2.3 engine that is.
80_2.3_ESS
I am getting ready to drop my new 2.5 into my Pinto, and I was thinking about the intake a little today.
I am running a Holley 390 CFM 4-barrel, on an Offenhauser intake. The motor is a 2.5 Liter from a Ranger with Hydrolic lifters and "D" intake ports.
My concern is that the intake has round exit holes (where it meets the head) and the head has "D" shaped intake holes. That means that the air / fuel mixture is going to hit a solid "step" when it tries to flow from the intake to the head.
I was wondering if there was anything I could do about it, short of grinding the intake ports on the head to make them round. Is there a better intake I can use that would still allow my 4 barrel to be used? Any advice?
Thanks!
Nick in CT
1980 2.3L Pinto ESS
