Date: 07/20/2018 03:00 pm
78-80 Windshield
Date: 10/29/2021 03:11 pm
Date: 09/12/2018 04:07 pm
Bumpers
Date: 07/06/2018 04:47 pm
Date: 10/24/2019 01:45 pm
Date: 05/22/2018 02:27 pm
Date: 03/16/2017 10:00 pm
Date: 02/18/2017 04:47 pm
72 pinto and 88 turbo coupe
Date: 06/09/2016 04:13 am
  • Online today: 344
  • Guests: 221
  • Total: 221
pvc valve relocation
Started by stonhed18, June 25, 2014, 11:04:53 AM
Or drill intake itself.............easy enough on most..............
stonhed18
Looks like Ill be making a spacer and tapping a fitting. Thank you for your wisdom!
Hmmm, good point that escaped me there, spacer under the carb would be the way to go, unless there's a spot to drill and tap for it??..
PCV entry should be in a PLENUM not individual runner, they always pass a bit of oil mist and not dispersing that to ALL cylinders can result in one plug oiling out pretty quick. Needs to be there as well for the straight air being mixed closer to equal in all cylinders, put it in only one and you can burn a piston from being too lean in that cylinder.......not the way to do it..............
You're welcome, looks like you're good to go..
stonhed18
Great! Thank you!  That fitting is too small but have one that will do the trick
Yes it can, you could also run your vacuum advance off that same fitting.. Looks like there's a fitting on there now?.
stonhed18
Thanks Wag :'(on! This where it was... can it be attached to the #1 runner with a proper fitting?
No, a PCV valve needs to be connected to a vacuum source, should be a spot at the carb base I would think???..
stonhed18
Ok I've finally put my "new" cannon intake on my 2.3. however there is no connection for my pvc hose. Can I run it to a breather on the valve cover to the oil vapor separator?
Any help would be greatly appreciated!
