1980 Pinto taillights
Date: 12/26/2017 03:48 pm
Hoard of Pinto parts
Date: 12/17/2016 04:14 pm
6.6.75 carrier
Date: 02/14/2018 06:47 am
Pinto Watch
Date: 06/22/2019 07:16 pm
Date: 05/24/2020 08:19 am
Date: 11/08/2020 02:10 pm
Date: 10/24/2018 07:35 am
Date: 02/18/2017 05:55 pm
Date: 09/09/2018 03:22 pm
  • Online today: 344
  • Guests: 229
  • Total: 229
V6 bypass hose inlet
Started by chrisa850, June 21, 2014, 08:46:25 PM
enzo
Sorry, I didn't read the post completely.  I have one that is usable if you can get the broken bolt end out of it.
Looks like the is enough material to carefully drill out the bolt and re-thread.
bbobcat75
your looking for the thermostat housing! good luck being alum. and a 2.8 part only will be a hard part to find that is good and not rotted out!! good luck - check the bay!! ebay
1975 mercury bobcat 2.8 auto
chrisa850
I have the bypass hose. The part I'm looking for is the aluminum inlet itself. part 8592 in the pictorial.
enzo
bbobcat75
I don't have a part number took it to a local parts store and just matched up a similar hose. Not a huge help but a thought! If you don't have the hose then hmmm hopefully some one else can shed some light here!
chrisa850
Does anyone have a source or part number for the 2800cc V6 bypass hose lower rear water inlet? It's the component labeled 8592 in the attached drawing. It doesn't seem to follow the standard D4/D5/D6FZ-8592xx part number.
