Date: 10/14/2019 08:24 pm
1978 ford pinto carb
Date: 02/04/2018 06:09 pm
1979 pinto
Date: 04/19/2018 02:02 am
79-80 full glass hatch
Date: 01/04/2017 04:04 am
Date: 01/19/2021 03:56 pm
1980 Pinto-Shay for sale
Date: 07/07/2016 01:21 pm
Date: 08/17/2022 06:27 pm
Radiator
Date: 05/27/2018 06:07 am
1972 Rallye wagon rebuild
Date: 11/14/2020 07:31 pm
  • Online today: 344
  • Guests: 229
  • Total: 229
1980 Engine and light harness connector pinouts
Started by JohnW, May 31, 2014, 06:56:19 PM
amxtra
  That would be awesome, I still need wiring diagram and/or pinout to figure out why cluster isn't working.
JohnW
Well I just got the factory wiring diagrams from factoryautomanuals.com and they seem to have everything I need. I'll try to upload scans once I find a place that can scan the giant sheets.
JohnW
Yeah, under the dash. I wish they were kept separate but both connectors share lights and engine related stuff
My bad, of course you mean the main harness plug ins. Yes, they often change wire colors under the wrap.
Dunno how I got instrument circuit out of your first post, dizzy I guess.
JohnW
I have the cluster at home and will be tracing out the leads to figure out that wiring. It's just a pain to trace out the original engine harness when all of the wiring is out of the car. I could plug it back in and hook up a battery if I have to.
JohnW
I'm not worried about the instruments right now. I have just the harness at home and am trying to figure out ignition on, always on power, etc. Hoping the manuals I have coming include pinouts as none of the other diagrams seem to.
There's the power for the stock ignition module, oil and water switch wiring, etc mixed in that I need to eliminate. I should've labeled all the plugs before I ripped the motor out and gave it to my dad
Actually even without the pinout you can trace like 75% or more of the circuits out by simply comparing the traces to each other while following them around the board. Grounds common to all needs will tell on themselves, i.e., you won't find power going to both backlighting and say oil light from same circuit, so they must split. The splits determine power into various things. How I do the simple early instruments like these have. I can pretty much trace out every single one. Then draw out your own pinout.
Just an idea but it works. If you have the skills to understand a pinout you are good enough already to do it.
JohnW
All of the diagrams I can find don't show a picture of the 2 connectors with a pinout. I need to know what each pin is for so I can trace the harness out and remove everything Pinto engine related and connect the Merkur harness for my turbo swap.
