Date: 07/20/2018 03:00 pm
Date: 08/13/2018 02:46 pm
Offenhauser 6114 dp
Date: 09/12/2017 10:26 pm
Date: 04/08/2018 05:47 pm
Date: 03/16/2017 10:00 pm
WTB Cruising Wagon
Date: 12/07/2016 05:35 pm
1977 Pinto Cruizin Wagon
Date: 08/07/2023 02:52 pm
Date: 04/20/2017 10:10 am
1977 Pinto Hatchback Parts
Date: 08/29/2020 05:31 pm
  • Online today: 481
  • Guests: 261
  • Total: 261
fuel injected 2.3 swap
Started by ddewey78, May 29, 2014, 07:52:29 PM
72pair
What year is your pinto? Currently a 2.0, I'll guess 71-74. If its a 71-73, then you're looking at some mods to install mounts and will probably need an electric fan in front of radiator due to clearance(2.3 is longer than 2.0 EAO).
I picked up a cheap 87 Stang 2.3/T5 2 years ago to do the same swap. I still haven't found the time to touch it but it looks simple to do since the engine harness & computer really isn't that integrated into the body harness. There are a couple people who pulled it off & I've seen the threads on here.
ddewey78
so i happened across a free 88 mustang with a 2.3. the current  2.0  just started knocking, sooo... the idea of an injected motor sounds great. Has anyone done this swap? any idea how much of a nightmare the wiring could be?
