Looking for a few parts - TIA
Date: 02/19/2023 12:18 pm
1970-1973 Gas Tank/Blue Dash
Date: 02/07/2019 11:57 pm
Date: 07/04/2022 07:55 pm
Date: 03/21/2017 07:47 pm
free transmissions
Date: 11/28/2019 10:21 am
Oddsnends
Date: 12/20/2016 10:52 am
Date: 12/10/2016 04:11 pm
74 Pinto Rear Side Lights
Date: 02/18/2017 05:47 pm
Looking for front seats
Date: 08/10/2021 09:54 pm
  • Online today: 344
  • Guests: 131
  • Total: 131
Weber Issue FYI
Started by jeremysdad, May 11, 2014, 03:20:13 PM
Scott Hamilton
Wow... Really? Can you buy new parts?
jeremysdad
Ironically enough, it worked it's way loose and laid down again this morning on the way to work. I'm about to go JB Weld the tube in place.
Check for tightness after the 'ding', sometimes plinking it just right loosens rather than tightens the part.
Scott Hamilton
Nope- did not record the numbers...  :(
jeremysdad
Might only apply to those of us that got bit by the 'genuine Weber' non-genuine Webers. I bet yours says 'Made in Spain' on the base plate, and I see your white choke housing.
Lol. :)
Yours look properly aligned. Did you, by chance, record your jetting numbers while you were in there?
Scott Hamilton
Ok checked mine...
I'm thinking mine are still good but I'm going to stake them (I assume I create a ding so they won't move on me) and consider this problem avoided...
Scott Hamilton
Wow-
I have noticed when I let up on the accelerator that I get a little bit more too...
I know what I'm doing today... Thanks for posting,
What's too funny is I to have a zip lock bag in the glove box with all the stuff to convert my distro back to points if I ever need it. -Like minds... :)
jeremysdad
Cost me a $125 tow bill, and 3 days of the wife not having her car (sorry babe!), but apparently the brass tube that runs in the middle of the venturis can work loose and rotate around. Mine was pointing almost straight up when I discovered it.
It started as a gradual 'accelerates better when you let up on the pedal' per the following quote, but got worse and worse to the point of driving a whopping 10mph down the shoulder of the interstate for 5 miles. lol I initially removed my Hot Spark and went back to points, cause it felt like a dying ignition module (had everything with me to do it on the side of the road).
This took a lot of Googling to come across, so I wanted to share with the group to prevent someone else from possibly throwing money at this wastefully.
To check for this, you can spray carb cleaner down the air corrector, it should shoot out straight down onto the butterfly. I used my leatherman to rotate the tube, and a 3 inch deck screw as a punch to stake it into place. Runs like a top again!
Quote (full link: http://www.apexspeed.com/forums/showthread.php?t=22373):
3) Lack of power. Well, you used to have more power, and you take your foot off the gas pedal a bit and the car goes faster. Check the auxilliary venturis. The brass tube inside has been known to get loose and start to spin around. take out the venturi, and see if the tube is pointing straight down....So you cant take the venturi out? turn the carburetor over and see if the tube is off centre. If this is the case, the tube from the venturi has taken a little wander into the main body of the carburetor. You have to move the tube to the middle of the venturi and then take it out. You have to stake the edge of the tube or buy a new venturi to correct this issue.
