Date: 10/01/2020 02:00 pm
Date: 01/12/2019 10:19 am
Date: 11/08/2019 10:01 am
Date: 01/19/2020 09:06 am
Seeking parts
Date: 10/18/2020 10:35 am
1980 Ford AM radio
Date: 12/22/2019 11:57 am
Date: 07/17/2018 09:22 pm
Radiator
Date: 05/27/2018 06:07 am
1978 bobcat 4speed shifter
Date: 11/02/2023 09:51 pm
  • Online today: 367
  • Guests: 164
  • Total: 164
Timing HELP!!
Started by YAYPINTOS, May 09, 2014, 06:47:05 PM
Quote from: jeremysdad on May 09, 2014, 11:53:18 PM
Idk. I point my rotor at the mark on the dizzy, and the car starts. Adjust it a few degrees further, and now we're idling. Has to be hot, though.
At a loss for the later POS motors. :D
LMAO..... ;D ;D ;D ;D ;D
;D :o ;D :o ;D
jeremysdad
YAYPINTOS
Ya I think my carb needs work... I can't get it to idle at all.. I'm doing it cuz I just rebuilt engine.
jeremysdad
Quote from: YAYPINTOS on May 09, 2014, 08:17:43 PM
It's dying when we try to Lower it but I didn't take the vacuum advance off... Would that do it?
Timing 'by ear' is a lost art. Go to Autozone. Buy a dial-back timing light. Once and done. :)
Also vacuum caps. You have to 'disconnect' the vacuum line to set the initial timing, so that requires plugging the feed.  A vacuum leak will mess up your idle, and throw off your timing.
Timing has to be done with the engine hot enough to burn you. Like a radiator hose burns you. Preferably the upper, but what do I know. :) rofl
kerryann
sounds like you are trying to time by ear?  what number did you lower it to?  why are you changing it in the first place?
Are you running ported vacuum or full manifold vacuum?, what is your timing set at now?, is the carb dialed in?, we need some info in order to diagnose anything..
YAYPINTOS
boughtabobcat
Not sure exactly what kind of help you need, but here's a link to my post about recently replacing my timing belt in which I got a ton of help from our fine members- hope it may help!
http://www.fordpinto.com/general-help/78-bobcat-wagon-2-3l-timing-belt/
kerryann
ive just went through a very difficult trial and error learning experience with this.  you are shooting for 34-36 total.  factory settings for initial are around 6-8 but more is ok.  i have finally gotten mine to 10 initial and 36 total.
What problems are you having?  do you have a dial back timing light or a standard?  have you checked timing yet? what do you have currently WITHOUT vacuum advance?
Not sure how savvy you are with the distributors but if you cannot get a decent curve they can be taken apart and the advance range changed by changing to different sized slots.  For my 1980 with duraspark distributor, 16L with a bushing on it turned out to be the magic number.  There are detailed instructions posted in other forums i can direct you to if need be.  You may not need to go this far though if you have a decent curve already.
YAYPINTOS
I need help getting the timing right for the stock 2.3l 1976 engine
