Interior Parts
Date: 08/07/2017 03:59 pm
Electrical
Date: 03/29/2017 11:37 am
1977 Pinto Cruizin Wagon
Date: 04/11/2024 03:56 pm
1980 Ford Pinto For Sale
Date: 07/01/2018 03:21 pm
nos core support
Date: 01/03/2020 09:39 pm
1979 hatch needed
Date: 05/13/2018 08:52 pm
1971 Pinto
Date: 03/04/2017 11:28 pm
Early 2.0 engines
Date: 05/09/2018 12:45 pm
Date: 03/16/2017 10:00 pm
  • Online today: 344
  • Guests: 229
  • Total: 229
2.3L exhaust gaskets
Started by Yelby, May 09, 2014, 07:59:15 AM
jburt
You're welcome.
My 74 exhaust has long studs at the manifold connection with springs on each stud. I imagine to help with vibration and torque loads.
I color outside the lines...
74 Squire Wagon - needs a lot of work.
Yelby
Thank you for the response.  I'll stop looking for donuts then !!!
jburt
I should have prefaced that response with; If you have the stock connections.
jburt
There is no donut or gasket at the manifold or the outlet of the catalytic converter. They are a direct bolt up. You will want to make sure both surfaces are clean and smooth, and the studs tightened equally.
Yelby
There is a flat two-holed gasket that goes at the front of the catalytic converter, is there a donut shaped gasket at the rear of the converter and at the exhaust manifold?
