1973 Pinto Wagon
Date: 05/06/2022 05:13 pm
Date: 05/15/2022 11:36 am
Date: 08/26/2018 06:23 pm
Date: 01/06/2017 11:42 pm
71-73 Hood
Date: 12/07/2018 06:22 pm
A.c. alternator hrackets
Date: 09/03/2017 12:11 pm
79 pinto steering column
Date: 08/18/2018 02:00 pm
Clutch Cable Needed
Date: 04/03/2017 10:54 pm
Date: 12/13/2016 10:25 am
  • Online today: 292
  • Guests: 256
  • Total: 256
Fuel system for turbo conversion?
Started by 8upwithpinto, September 20, 2003, 11:25:29 AM
Killer74
Quote from: 8upwithpinto on October 28, 2003, 04:20:55 PM
The XR4ti sounds like a strange animal. Need to chex one out. Wounder if the pump would work alone?
I have one....a really neat little car! Quick, and handles great. Of course mine is modded all to hell! ;)
*74 Turbo 2.3 Pinto
*77 351w Turbo Pinto (still in the works)
8upwithpinto
80 Pinto
91 5.0 LX
02 Mustang GT
01 ZRX1200R
When i built my F.I. StangII i used a Ranger truck inline pump.i had a holley blue pump to pull fuel out of the tank, and feed a 1gallon surge tank. The Ranger pump pulled fuel out of that to feed the engine. This setup never starved a mildly built 5.0 Everything was steel lines, and flare fittings up to the enginewher i had one piece of high pressure rubber to connect to the fuel rail.
Killer74
yeah the Merk has an external pump and I've never had any starvation.
*74 Turbo 2.3 Pinto
8upwithpinto
Does the Mercur have an external fuel pump? And does your car starv for fuel at a 1/4 tank?
80 Pinto
91 5.0 LX
02 Mustang GT
01 ZRX1200R
Killer74
I have the stock tank with a Holley Blue pump pulling from the tank and feeding an XR4TI inline EFI pump, I used 3/8 alum. line and welded a return fitting at the bottom of the filler neck.
*74 Turbo 2.3 Pinto
8upwithpinto
Use high pressure fuelline/pump o.k. cool. I raided the whole fuel lines off the T-bird, the're plastic. Do you think I could trim/splice them to still use the factory filter? Also any mods to the sender/pick up? Pump position?
80 Pinto
91 5.0 LX
02 Mustang GT
01 ZRX1200R
You need a good high pressure inline pump. You will also need to run two high pressure lines, one from the pickup in your tank to the fuel rail and the other a return from the fuel rail to the tank.  Some people just use thier existing fuel line to use as the return to the tank but i personally don't like that idea. The return can be plumbed into the filler neck that goes to the tank (remember.... no sparks!)    Jeff
ps.  MAKE SURE YOU USE HIGH PRESSURE FUEL LINE!
8upwithpinto
 Hey! Can anyone suggest "how to" mod my fuel system for a turbo conversion? My car is an 80 hatch auto. I have a complete engine/trans out of a 85 t.c. Also have wiring & e.c.u. Any info would be great!
Thanks
80 Pinto
91 5.0 LX
02 Mustang GT
01 ZRX1200R
