1976 pinto for sale
Date: 01/12/2017 02:08 pm
1979 Pinto Rear Bumper
Date: 03/26/2021 03:26 pm
rear hatch back louvers
Date: 04/18/2017 12:44 pm
Date: 12/09/2018 11:35 pm
NOS Sedan decklid
Date: 10/23/2019 11:51 am
parting out 1975 & 80 pintos
Date: 04/28/2018 04:12 pm
Date: 11/05/2016 09:03 pm
Date: 08/01/2023 06:53 pm
Mustang II C4 Transmission
Date: 07/28/2017 06:26 am
  • Online today: 394
  • Guests: 337
  • Total: 337
which cap for this valve cover?
Started by poomwah, April 28, 2014, 09:46:41 PM
poomwah
right, the breather fit perfectly. The cap they had listed had the wrong thread.
I took the valve cover into a different store and matched it up.
D.R.Ball
The breather is a push on not a thread on, the oil filler cap is a screw on...
poomwah
got the breather elbow today, but the cap that they had at autozone won't thread in.
poomwah
Stand offs look about a 1/2" tall, I'd say you'll need new bolts.. :D
poomwah
me too :]
now if my gasket ever gets here :P
I wonder if I'm going to need longer bolts
poomwah
got the valve cover today.
still haven't got my gasket or cap though :\
poomwah
I dont' have that valve cover to measure the hole
poomwah
Quote from: Pinturbo75 on April 29, 2014, 12:18:04 PM
as Shelby said, the rear breather had a vacuum line that went to the inlet of the turbo... I run a regular push in breather on both of mine....
what kind of breather do you use? do you have a link or a part number? I don't know what size the hole in the grommet is.
poomwah
I figure I'd just emulate what's there now. Keep the PCV on the side of the block, and run a breather off the back of the valve cover, either to the air cleaner, depending on which air cleaner I use, or a separate filter.
Quote from: Pinto5.0 on April 29, 2014, 01:30:27 PM
Once I get everything together & running I'll be selling off any extra parts. The only problem I have right now is not knowing what all I need.
That's cool, keep me in mind.
Quote from: 74 PintoWagon on April 29, 2014, 12:31:53 PM
Wanna part with one. :D
Quote from: Pinto5.0 on April 29, 2014, 11:53:40 AM
I've got several early aluminum turbo valve covers.
Any problems keeping the cover clean around the breathers?.
I've got several early aluminum turbo valve covers & that back hole was run wide open. I've seen guys do all kinds of things to put a hose on it but when it was stock it sucked in crap from the engine compartment
I plan on putting an aluminum cover on mine too so I'll probably end up re routing stuff around also,lol..
Quote from: 74 PintoWagon on April 29, 2014, 09:51:48 AM
Different years I guess, mine has the oil cap in the rear and goes to the air cleaner and no breather in front, it does have a PCV that goes to the block. That one has a small hole that could be the PCV???
You're right, my 76 cap is at the rear. I was thinking of the 87 engine I have with the cap at the front. I think it's got a vent at the rear though so I'm gonna have to see how Ford routed it. I'm planning to run the 87 engine in my 76 with the same aluminum valve cover as this post is about so I've been trying to figure this out myself before I drop it in the car.
No because when vacuum drops the PCV valve closes then air is drawn from the top, it's an enclosed system.
Then it ought to be safe to plug the one in the valve cover.
Mine has a small can coming off the block just above the oil pan then a curved hose, the the PCV valve and a hose going to the EGR adapter..
The rear port on the TC valve cover is indeed for the PCV. It was originally routed to the compressor inlet elbow on the turbo, but the the air filter housing or a catch can on NA engines should be fine. The 2.3T engines had a big can-shaped oil separator/PCV valve, though. Not sure if that's needed or if there are baffles under the PCV port to keep oil spray down. It's been a long time since I've been under the valve cover of a 2.3T.
Quote from: 74 PintoWagon on April 29, 2014, 07:51:55 AM
Doesen't the back one go to the air cleaner, mine does? ???
If it goes to the filter it's atmosphere. My 76 doesn't have a rear vent but the oil cap vents to the air cleaner I think.
Doesen't the back one go to the air cleaner, mine does????
Is that separator at the rear supposed to be connected to vacuum or vented to atmosphere?
