Custom Pinto Project
Date: 06/12/2016 07:37 pm
Date: 08/13/2018 02:46 pm
Wanted hood hinges
Date: 02/17/2020 05:30 pm
Sunroof shade
Date: 06/19/2019 01:33 pm
1978 RUNABOUT
Date: 04/01/2017 03:18 pm
Date: 10/28/2018 08:45 am
Front sway bar frame brackets
Date: 07/13/2017 01:05 am
Date: 12/26/2016 04:29 pm
78 pinto wagon
Date: 06/04/2020 12:42 pm
  • Online today: 628
  • Guests: 514
  • Total: 514
2.3 mods part 2
Started by slowride, April 28, 2014, 08:33:42 PM
slowride
The mods continue. The biggest issue I found with using a Weber 38 is it use the inboard throttle shaft whereas the 32/36 uses the outboard  (primary). That means the rotation is opposite, so rather than dick around with a bellcrank (which only complicates a kickdown), I decided to make the outboard shaft work off the cable.
I had a spare 32/36 which supplied the bracket for the throttle shaft. All I had to do (so far) is grind the staking off the old shaft, drill it to use the little hub on the new "gear" as a center, drill and tap the new shaft to hold the bracket on, and clearance the ear on the throttle spring. I have one more fastener to design to ensure the gear is secured on both sides, but that shouldn't be a big deal. (old 38 bracket on the right is coming off)
I should be able to use the stock cable bracket, cable, and kickdown once it's assembled.
