Date: 03/07/2017 07:03 pm
Date: 07/08/2017 08:53 pm
Date: 09/26/2019 05:31 pm
Date: 02/28/2018 09:18 am
Front Body parts needed
Date: 02/09/2018 06:09 pm
Date: 12/30/2022 01:30 pm
Electrical
Date: 03/29/2017 11:37 am
Pinto Vinyl Top
Date: 10/09/2020 10:29 pm
Date: 10/15/2017 10:03 am
  • Online today: 452
  • Guests: 356
  • Total: 356
Another axle setup question
Started by don33, April 28, 2014, 01:11:00 PM
don33
ok, not sure if there is any difference there, dia, thickness of material ?
I got one from a crown vic and had it shortened and new ujoints and correct ends added
don33
Got it, that's what I was thinking would be right. thanks to all... one more question for Pinturbo, what driveshaft are you using ? not sure weather I need a bigger/stronger one or not ?
im running a 2.3 turbo with t5, aluminum driveshaft, and 8.8... to start off with I used the opposite angle of the trans and then added 2 degrees of negative offset on the rear.. only because I drag race the car occasionally.. that extra allows for the rear to correct alignment under hard acceleration....
Rob3865
don33
Pinturbo75, its not exactly a standard/stock setup. it's a 2.3T with a C4, a Aerostar aluminum driveshaft and a narrowed ford explorer 8.8 rear axle assy. that being said, would there be any difference in the pinion angle setup ?
its pretty simple if for a stock app.... it needs to be the exact opposite of the angle of the trans
don33
don33
does anyone know what the pinion Angle is on a 80 pinto, I'm sure its the same for 74 and up...
