1979 pinto
Date: 04/19/2018 02:02 am
Date: 08/09/2018 11:09 am
72 Pinto
Date: 03/07/2019 12:07 pm
1980 hood needed
Date: 04/23/2020 10:41 pm
Mustang II C4 Transmission
Date: 07/28/2017 06:26 am
WANTED Hood Prop Rod
Date: 01/17/2017 02:47 pm
Date: 11/29/2018 10:26 am
Date: 08/13/2017 02:01 pm
Date: 06/22/2017 07:19 am
  • Online today: 553
  • Guests: 213
  • Total: 213
Leak into the footwells
Started by ParkerPinto, April 26, 2014, 09:00:21 PM
jeremysdad
Quote from: 82expghost on April 29, 2014, 12:04:12 AM
i was getting allot in my footwells, after the windshield gasket, still had leaks, cleaned the cowl, still had leaks, sat in my car in a torrential downpour and found it was my door gasket right at the dash area
Good tip. If it happens to one, it could happen to any of them. :)
82expghost
98 taurtus, now in heaven
77 pinto, weekend warrior
92 grand marquis, daily
If the vents are plugged the water will flow over the top of the vents & run into the car during a downpour. If it sits outside a good car cover will keep the crud out year round.
jeremysdad
It's probably the windshield gasket.
Mine leaks like a sieve.
rramjet
I was able to clean mine out by pulling the inner fender liners out and working from the end of the drain. You need to pull the air vents under the dash out and clean the area behind them as well. If you are lucky the junk hasn't been there long enough to rust the area around the vents out.
Something that has worked for me is to cut a piece of window screen about an inch oversize of the cowl vent.  I then use flat strip magnets around the edge to hold it into place.  It sure helps to keep the garbage out of the cowl. And in about two seconds it can be removed.  Never had it blow off yet while driving (under 70 MPH).  I'm going to try masking the screen off and using a rubberized spray (like Quick Seal) to permanently fix the magnets to the screen.
But, yea pulling the fenders is about the only way to clean that area out.
They're under the fenders. It's a bit of work but pulling the fenders & flushing all the crud outta the cowl is worth the effort. As long as you didn't end up with rot from the build up a good cleaning, drying & then copious amounts of Rust-Oleum paint will fix it permanently.
ParkerPinto
Got a '72 wagon that sat unmoved for quite some time. It's leaking when it rains I believe from the cowl underneath the dash. I'm trying to find the drains for the cowl...anyone know where they are? Thanks
