Date: 12/30/2022 01:30 pm
Date: 08/16/2018 08:54 am
MISC PINTO PARTS
Date: 08/27/2017 10:23 am
Date: 06/18/2018 03:47 pm
ford pinto door panels
Date: 03/20/2022 07:51 pm
1974 Ford Pinto
Date: 10/16/2017 10:45 am
Interior Parts
Date: 08/07/2017 03:59 pm
FREE PARTS!!
Date: 01/10/2017 02:38 pm
Date: 10/05/2017 02:26 pm
  • Online today: 502
  • Guests: 474
  • Total: 474
Air out of dash vents only.
Started by Tercin, July 02, 2005, 10:19:43 PM
Well I'm not quite 40+ in either direction... yet, but it's STILL painful to contort up under the dash!
I assumed the A/C controls were similar to the non-A/C cars with the cables. I oughtta know better... never assume anything... it always makes an butt out of u & me LOL
dirt track demon
Quote from: Tercin on July 04, 2005, 12:11:13 AM
It seems less painful for us 40+ guys.
that depends on whether 40+ is your age or your waistline.
Fomoco's biggest achievement:
The PINTO!!
Fomoco's biggest mistake:
Tercin
Thanks for the input. I will check it out. I had the heater control pulled out but I wasn't sure what I was looking at. however I didn't see anything broken. I will have to become a contortionist. I will check for vacuum lines under hood first. It seems less painful for us 40+ guys.
The only Pinto I have
73 Sports Accent
Rust free California Car
The  73 A/C Pintos heater controls are vacume operated.
Check for under hood vacume lines are attached.
Sounds like your cable had either come undone, or broken. The HVAC has 2 cables, one to control temp, one to control output. Two screws will have the panel out, but don't pull real hard on it. There are some pretty fragile (after 30 years) plastic pieces in there. If the cables are intact at the control end, then go ahead & reinstall the control head. If not repair & enjoy!.
Getting at the airbox ends of the cables requires a contortionist! While standing on your head, check the cables where they move the "flapper valves" on the airbox. Again there are a few fragile plastic pieces here, so don't go yanking on anything. You're looking to see if the cables are actually moving anything. If they are... Scratch your head & wonder how the heck you're gonna get that airbox out, cause it's broken internally.
If I were a betting man, I'd bet on one of those fragile plastic pieces being broken.. The cables are about 1/16" thick, so they CAN break, but rarely do. If the cables are all ok, then the "flapper" valves in the airbox aren't working. If this is the case, then get ready cause this is an adventure!
Tercin
I have a 73 with a/c and I can't get air to flow anywhere except out of the vents in the dash. When I move the selector to any other setting the air still comes out the dash. No defrost, Hi-Lo etc. I hear the a/c compressor kick on but it doesn't seem to get cold. Just air blowing out of the dash. Help.
Thanks
Tercin
73 Sports Accent
