pintos for sale
Date: 12/11/2018 04:29 pm
Date: 09/15/2019 08:30 pm
75 wagon need parts
Date: 05/28/2020 05:19 pm
SVO SWAP
Date: 03/15/2018 03:12 am
2 Station Wagons for sale
Date: 04/20/2018 11:10 am
Date: 12/09/2018 06:59 am
79 pinto steering column
Date: 08/18/2018 02:00 pm
Date: 02/18/2017 04:47 pm
  • Online today: 525
  • Guests: 180
  • Total: 180
exhaust work
Started by poomwah, April 12, 2014, 03:14:49 PM
Cheap non-foulers for spark plugs make a good bung once you mod them a bit. The big one for big 18 mm. plug as he says.
Shouldn't have a problem then.
The sensor is a 18 X 1.5 MM with a .649 dia hole for tapping. And you can buy an extension for the O 2 sensor that could be welded to the header it taping was not possible.
Depends on the sensor size I guess?, but yeah you could whack the threads off and tap it, you got over a half inch.
On a Ranger header, you can saw the threads off and then tap the hole metric for the O2 sencor. (I THINK)(HAVEN"T TRYED IT YET)
I just put a press plug in mine.
poomwah
I made a "cap" for the EGR fitting on the manifold.  I could have welded it shut, but this way if I ever switch to efi, I've got a  fairly easy place to put an O2 sensor.
I took an original EGR elbow. cut the male threaded section off, then tapped the hole that was left and threaded a bolt into it. Then cut the bolt of flush .
Quote from: 82expghost on April 19, 2014, 05:57:06 AM
egr makes your intake dirty, show me clean exhaust pipe, the by products that come out of your exhaust eat up your valves and seals, it makes your engine run so much cleaner, i understand its to get the left overs and burn it, but at the cost of wear? and the pcv vent, scavenge that off into your exhaust, the fumes that come from that can gunk an egines intake, engines are living organisms, they need clean air too, sorry, its a pet peev
Friend of mine long time ago took all that junk off of his dually and put a Vac-U-Pan system on it, cleaned everything up and never had any leaks and got 3 more miles to the gal.. :D
82expghost
98 taurtus, now in heaven
77 pinto, weekend warrior
92 grand marquis, daily
If working right it does not. It is off at anything approaching full throttle and off at idle. It only works during cruise when you don't WANT power.
82expghost
people still run egr? egr kills the ponys, remove the cancer!
Quote from: poomwah on April 17, 2014, 09:43:37 PM
its one of the stainless ones amc.  not that I'm a fan of welding stainless, but i definitely wouldn't try it on cast
I'm cutting that tube about 1/2" from the header, heating the nub & pinching it closed then welding the seam. Should be 10 minutes work.
poomwah
Good way to crack it if cast iron. Any way you can drill/tap for a slightly larger common plug?
poomwah
I got my  manifold!
How are you going to do your egr port?  I was hoping it was a female thread and I'd be able to put a plug in it. Do they make a cap that will thread on it?  Or should I just make a plug and weld it in ?
No, it dumps out at the back but if you shorten the pipe it will line up, Fred Morgan showed me his and it was hooked up to his original system, he said it was a piece of cake to do it.
poomwah
thanks art, does it look like the ranger header dumps out at the same location and angle?
Haven't put mine on yet so I don't know for sure, but I was told it did???..
poomwah
Does anything need to be changed on the exhaust system when switching to the ranger manifold?
The front flange on my cat rusted off. My exhaust behind the cat is almost new.  It would be pretty easy to weld in a piece of pipe where the cat was.  But I'm wanting to get a ranger header as soon as possible.  Will the stock down-pipe bolt to the ranger maniofld?  I don't want to put any money into my exhaust just to have to modify it as soon as I find a ranger manifold.
