Date: 03/16/2017 10:00 pm
1980 pinto/bobcat floors
Date: 07/24/2018 08:11 pm
1971-1975 Pinto
Date: 01/09/2017 04:14 pm
72 Pinto
Date: 03/07/2019 12:07 pm
Automatic Wagon
Date: 06/14/2019 11:22 pm
1976 pinto for sale
Date: 01/12/2017 02:08 pm
Date: 02/28/2024 02:07 pm
Mallory Unilight dist 2.0
Date: 10/25/2019 03:44 pm
New cam
Date: 01/23/2017 05:11 pm
  • Online today: 489
  • Guests: 154
  • Total: 154
turbo or SC
Started by YAYPINTOS, April 10, 2014, 08:36:37 PM
Craigslist has been my best source
YAYPINTOS
gotcha, do u know where i could find a turbo engine or even just a bigger engine then the stock that would still bolt right up?
Quote from: YAYPINTOS on April 10, 2014, 11:01:04 PM
soo i would need more than just forged pistons?
Yeah, a turbo head has a D shaped combustion chamber as opposed to the Pinto heart shape. A turbo block is tapped to feed & return oil to & from the turbo. A whole turbo engine can be had for a few hundred dollars while good forged pistons can run double that.
YAYPINTOS
Quote from: YAYPINTOS on April 10, 2014, 09:53:05 PM
if i where to get the forged pistons would it be ok?
Since Ford was kind enough to supply Pinto owners with plenty of factory 2.3 turbo engines in Tbirds, Mustang SVO's & Xr4ti's that bolt right in & are sporting forged pistons & everything you need to double or triple HP over a stock Pinto there really is no reason to build your own from scratch.
YAYPINTOS
poomwah
neither would be a good choice on the stock 2.3 because the normally aspirated uses cast pistons instead of the forge pistons on the turbo.  Putting the turbo on an engine with cast pistons will probably melt the pistons.
YAYPINTOS
What is cheaper to install, what is better, and can they be installed on the stock 2.3l
