Date: 04/04/2020 09:38 am
door sills
Date: 03/14/2020 03:20 pm
FLOOR PANS
Date: 06/12/2020 07:24 pm
Pinto Vinyl Top
Date: 10/09/2020 10:29 pm
1980 cruising wagon ralley
Date: 07/12/2019 01:41 pm
Date: 03/06/2019 06:40 pm
Date: 02/18/2017 05:52 pm
Date: 12/04/2018 07:40 pm
79 pinto steering column
Date: 08/18/2018 02:00 pm
  • Online today: 376
  • Guests: 405
  • Total: 405
3 inch exhaust....
Started by Rob3865, March 31, 2014, 12:03:14 AM
82expghost
thats amazing, i didnt think it was possible, i was thinking no way with a lowered pinto, but i stand corrected.
so 4 inch radius on a 3 inch pipe will clear? any clanking from when the axle creeps forward and back?
98 taurtus, now in heaven
77 pinto, weekend warrior
92 grand marquis, daily
 "Look how low the muffler is and you will see why the 3" pipe can go under the rear end easyer than over it."
In fact, that is often what we do on our Sunbeam Tigers.
A regular heavy floor jack won't fit under the front subframe rails of mine.
I think I would prefer to use a long glasspack-style muffler ahead of the axle if a regular one wouldn't fit behind the rear valance. Or maybe oval tubing...
Not sure these are the same but something to look at.  Mike Modified has photos of a 3" exhaust in his thread, scroll down a bit.
http://www.fordpinto.com/general-pinto-talk/2-3-turbo-pinto!-different-ecu-or-chip-mass-air-flow-3-inch-exhaust/?topicseen
According to my notes, these are from map351.  Their web links went bad so photos are attached below.
I'm the one with the "Black Suburban". BTW, the 3" exhaust will go under the rear end with no more trouble than going over the rear end and will be with less bends. This message will self destruct in 10 seconds.
If you play the Watergate tapes backwards this information will be revealed.  ;D   Did you know that "Deep Throat" is not actually a Watergate informant. Deep Throat is actually a "code" term for 3" exhaust.  It's true. I got this information from the same place I learned about FEMA Coffins and Chem Trails.  :D
Quote from: 65ShelbyClone on June 12, 2014, 11:11:36 AM
Is it something that can't be shared publicly?
He'd have to kill you if he told you publicly ;)
Quote from: dick1172762 on March 31, 2014, 11:18:02 AM
PM'ed you with a link for 3" exhaust.
Quote from: Rob3865 on March 31, 2014, 02:33:11 PM
And replied. Thank YOU very much! That's exactly what I was looking for.
Rob3865
Thanks. I was thinkin 4" radius, but was not sure. I can order all my bends from Summit. Muchos gracias fellers.
I think all my bends are on a 4 inch radius, I started with a 45 on the up leg to a 90 over the axle and another 45 to the muffler
Rob3865
Rob3865
Thank you. I was thinking it could be done. Do you happen to remember what radius bend it took to go over the rear axle?
yep, 4 inch down pipe from turbo to 3 inch all the way back on the wagon... and the sedan,  with a v8 adapter and bellhousing i still got 3 inch downpipe and all the way to the rear bumper...and ive have personally seen one with 3 1/2 inch from turbo back..
Rob3865
i believe there are a couple of guys who have. i have.
hang around, they'll chime in soon
Rob3865
I am curious. Is there anyone on here who has successfully a single 3" exhaust over the rear axle? Pictures? Thanks.
