Seeking parts
Date: 10/18/2020 10:35 am
Dumping '80 yellow Pinto
Date: 06/21/2017 03:45 pm
Date: 04/24/2018 11:45 am
Date: 01/23/2017 07:41 am
Date: 03/06/2019 06:40 pm
74 hood
Date: 07/03/2017 03:46 pm
Early 2.0 engines
Date: 05/09/2018 12:45 pm
Date: 11/05/2020 06:32 pm
Date: 10/31/2018 12:04 pm
  • Online today: 489
  • Guests: 248
  • Total: 248
burning oil?!?!?
Started by YAYPINTOS, March 29, 2014, 10:56:30 PM
Rob3865
Yeah. That'll do it. That joker would be getting a small block at my house. lol
YAYPINTOS
Well I got it out and the cylinder is pretty good! Just gana hone it a bit and call her good
That definitely stinks. I'm hoping to swap my wagon engine before the pre-ignition does that to one of my pistons.
That sucks, hope there's no other dammage.
YAYPINTOS
It's the first piston, has a hole in it!
jeremysdad
Valve stem seals are always suspect on cars of this age. When I disassembled my head, mine literally fell apart, they were so brittle...especially the exhaust valve stem seals.
I agree with the suggestion for the compression test as a starting point, though. A compression test will tell you sooooo much about the overall condition of a motor. You can rent one from a parts store (you get a refund for the price when you return it).
YAYPINTOS
ya it smokes and i found a bit of oil on the ground so it is leaking a bit.. :'( :'(
rramjet
Typically bad valve seals cause smoke on start up from oil that has drained into the cylinder past the valve stem where the seal is leaking.
Rings are more likely to cause smoke on acceleration and general driving if bad enough.
amxtra
  I have had a few 2.3s over the years that were using oil and it was only valve seals.
Rob3865
Only one way to diagnose it. A compression test. Pull all the plugs. run a compression test. Record the numbers. Should all be within 10% of each other. If you find a low or dead one, put about a teaspoon of motor oil in that cylinder and try again. If it comes up, the rings are bad and the oil is sealing them. If it does not come up, you either have a hole in a piston or a burned valve. Simple to verify. Using your compression tester hose, apply compressed air to the dead or low cylinder with the valves to that cylinder closed. Air rushing out of the tailpipe indicates a bad exhaust valve. Air rushing out of the carburetor indicates a bad intake valve. Air rushing out of the valve cover oil filler indicates bad rings or a hole in a piston. Pretty simple, really. It's not rocket science.
Check for leaks first.  Does the car smoke? Going through oil fast likely shows as smoke - unless it is leaking.  When you say you took the spark plugs off I assume you mean the wires.  If you pull the actual plug it will show either oily or at least very black/oily.
I've had old cars that I drove home at 30 MPH because they were not firing on all cylinders.  I'd clean the offending plug, drive it a little and it would foul again.  After about 5-6 times the fouling stopped and I had no issues for the three or so years I owned the car.
I've also seen cars with somewhat loose plugs and a leaking valve cover.  The oil leaks down onto the plug and works it way past the threads fouling the lug.
So,
1. Check for leaks.
2. Pull the plugs and look for oil fouling. Try cleaning the plugs and see if that helps.
3. If the problem persists do a compression check.  Parts stores may even have one as a "lend" tool.
Report back findings.
YAYPINTOS
Ya, I took the spark plugs off one by one and the only one that didn't rlly make a difference was the first one.
Jerry merrill
I was blowing some smoke and using more oil than normal and I changed to a new head with new valve seals, problem gone! Check compression on that cyl. compared to the others.
Could be a dead valve seal or guide too.
YAYPINTOS
Im going through oil at an extremely high rate, I've narrowed it down the the first piston. could it just need a new ring?
