PINTO TRUNK LATCH & CATCH
Date: 03/23/2018 09:39 pm
Date: 10/05/2017 02:26 pm
1979 pinto
Date: 04/19/2018 02:02 am
Bumpers
Date: 07/06/2018 04:47 pm
72 PINTO WAGON
Date: 09/23/2018 06:16 pm
Date: 09/12/2018 12:33 pm
1978 Squire wagon 6 Cly
Date: 02/16/2020 05:42 pm
77 Wagon rear hatch
Date: 12/04/2019 05:57 am
Date: 08/20/2017 01:34 pm
  • Online today: 500
  • Guests: 321
  • Total: 321
extended wheel studs
Started by L.D, March 14, 2014, 09:19:20 PM
LD! It'll give your car the anti ricer look too. Hood pins next!
Yeah, at like 650 degrees, you have to melt the Loctite before it comes loose. I'm not big on doing that on a good part. Blue, like mentioned, use more liberally, it still comes loose.
If you use red you'll need heat to get them out.
ONLY use blue if you ever want to replace one.
beaner
Quote from: dick1172762 on March 15, 2014, 12:27:21 PM
I drilled 4 new holes, tap them 1/2 20 and used ARP bolts which are 1/2-20 allen bolts that are threaded all the way to the head.  Easy in and easy out if you need to replace one. Got them from Jegs. BTW there is plenty of room for the new holes on the rotor. Worked for me.
dont foget to use locktight when doing this
brad :)
Quote from: L.D on March 14, 2014, 09:19:20 PM
I need some extended wheel studs for 71 rotors .565 knurl diameter anybody have any ideas.
LD, when I did mine a few years ago, I could not find exact fit long studs (maybe they do them now?). Below was my solution using ARP studs. I had to have spacers machined otherwise the wheel lugs would not seat. I installed the studs myself using an old Cortina wheel by cinching down on the lugs as I taped on the backs. It worked great. What you see are 71 rotors that were cross drilled and coated for storage.
Go to auto parts store and have them pull out the Dorman catalog and start researching studs..............they either make 'em or they don't.................
L.D
