Drip rail chrome
Date: 01/14/2017 09:18 am
front end parts
Date: 03/30/2018 12:48 pm
Pinto hubcap
Date: 01/07/2017 08:40 pm
77 pinto
Date: 08/22/2017 06:31 pm
Date: 09/03/2018 08:58 am
Date: 03/13/2021 12:57 pm
Date: 04/20/2017 08:56 pm
1974 Pinto Door Handles
Date: 03/07/2017 04:06 pm
Date: 12/24/2016 04:13 pm
  • Online today: 500
  • Guests: 274
  • Total: 274
new here and need help
Started by aimone, June 28, 2005, 11:34:20 PM
BlueGoldPinto
Ok, now I must stress the importance of good spot welds, trust me it will save you a lot of time later. Make the welds relitively close together for strength purposes. remember, this is a floor your welding ;) Ok, now that you have that new board in, you'll want to grind down your spot welds, just to make them smooth, but do not grind them down to the point where you completly remove them! After that you will want to get out the bondo, hardner, bondo board, severle good spatulas of various sizes, and you might also want something to mix with, although a spatula would work just as well. Again make sure the metal is clean and is a good surface for the bondo to stick too. Don't mix in too much hardner or you will have to work very fast to get the bondo on and smooth. When you start working the bondo keep concentrated and keep it as smooth as possible. remember to follow curves and when the bondo starts to harden, throw it out!! working with hard bondo will waste you time in the future and might possibly mess up your whole work!! It will take less time to mix a new batch than it would to fix your mess up later. Now that you have your bondo down, give it a little time to dry and harden, and start to sand. depending on th area, you might find that a block sander works best, or just some regular sanding pads and elbow grease suits you fine. HAND SAND ONLY!! some may disagree with this but in my opiniun taking your time to produce quality work is worth it. Take off to much bondo and again your in a mess. Contine the process of hand sanding and adding bondo until you get what you want. You want to barly be able to feel the difference in height where the bondo meets the metal. remember to leave enogh bondo for feathering in so you CAN"T feel the difference as I said above, and it leaves a much neater job. After you get all the bondoing out of the way, the rest should be relitivley smooth sailing. Put on several coats of primer, you might want sandable primer to make it easier for you, but again its up to you, and as you probably know there are different primer colors dependingon the finised color that you want to paint the floor with. If you were going to recarpet the floor an immiticulate job might not be needed, so it is good practice for you, but if not, you might take a little more time for each step. Again tough, if you cannot find replacement floor plans, you may want to buy some sheet metal, 14-16 gauge. The steps are basically the same, except that some bending with a hammer or cutting with some metal snips or an air cutter might be required depending on where you want to patch the floor at, and again, take your time, if there are a lot of curves, cut out little peices and spot weld them, don't try to make an elaborate curve or I predict it will end up kinda ugly :o If you have never welded or Bondoed before you might consider taking it to a body shop, or, it is just the floor and it would be a perfect place to learn to repair and gain skills for a lifetime!!! I hope all this helped or at least gave you an idea of what to expect before you start that major repair job. Good luck and keep your PINTO rolling! ;) :D ;D :)
BlueGoldPinto
Well, what you want to do about the floor-boards is replace them. Trust me that is the safest and best way to repair this situation, even though it is time consuming, and requires some skills you may or may not have. If you can not locate floorboards for you vehicle you will need to buy some relitively thick gauged metal.Im not exactly sure- mabye 14-16 gauge, somebody help with that ???.  If you can locate floorboards, grind down the exsisting welds on the rotting floorboard, until the floorboard comes out. Some hammering and cutting might be required on this, depending on how much trouble your floor wants to be for you. once you get the exisiting floor out, grind, grind, grind! you want to get the metal as clean and as free from rust as possible, and you also want to get any sharp edges to make a smooth surface to mount your new boards, and to prevent any bloodshed ;). Next, you will need to be able to hold the new floorboard in place while you weld it to your grinded metal. make sure that the metal is clean and free of primer, paint, oil from your hands...anything that may prevent the metal from welding properly. Do that and I tell you the rest later.
aimone
well im new here and new to owning a pinto i have a 77 cuising wagon with the bubble windows and a 4 speed 4 cylinder its two toned brown and gold but i need to know a few things and need you guys help if possile the rust how do i fix it the back floor boards ar almost gone from rust i will soon post pictures and how do u hook up and newer style sterio? pleease help me on this
                                                             aim-one
