Wanted 73 pinto squire wagon
Date: 05/09/2020 11:59 am
1976-1980 A/C condensor
Date: 09/21/2020 10:43 pm
Date: 05/18/2020 10:22 pm
Date: 08/26/2018 06:35 pm
1971 Pinto (survivor)
Date: 05/15/2022 04:42 pm
Deluxe Steering Wheel
Date: 10/16/2017 08:13 am
1971 Pinto 5.0L
Date: 12/02/2017 12:23 am
1976 Squire wagon
Date: 09/12/2018 10:30 pm
postal pinto
Date: 06/03/2020 09:31 am
  • Online today: 531
  • Guests: 474
  • Total: 474
crazy sand blasting paint stripping question.....
Started by D1, March 09, 2014, 03:14:19 PM
Possibly. I know for sure you can't glass, BTDT, the results are 'less than satisfactory' we'll say. I know the modelers things work, I've done them on polystyrene before. The radio face will be close to that type plastic if factory Ford part.
Not aftermarket part is it? If like polypropylene (PP) you will never get paint to stick, it will not on oily base plastics. ALL plastics are oil based but some hold far more oil in the finished product than others, the oil effuses to delaminate all paint put on. Vinyl paint may work in that case, it flexes to help stick better.
nnn0wqk
You could probably soda blast it and not hurt the plastic.
What kind of paint, enamel or lacquer? Any paint stripper worth its' salt will eat the plastic too. There are many now that don't work for spit but leave the plastic alone. You can always try like Purple Power or Easy Off oven cleaner, what plastic modelers use to strip paint on plastic models without hurting the base plastic.
You cannot sand or glass blast plastic, the erosion friction melts it. Maybe VERY light glass bead might work but no guarantee there. Not the way to do it.................
D1
I am trying to paint/changethe color of the plastic radio bezel in in my jalopy....the first coat looked like a black orange peeling when it dried....even after I scuffed and cleaned it with soap and water and let it dry over night......I have tried sanding it off and hit plastic on the corners and I am affraid I an going to weaken the integrity of the plastic if I continue sanding.
Has anyone ever tried blasting this part? If so what were the results?
What about paint strippers, how will they work on this part or will they eat into the plastic?
Thanks in advance
Thanks
May the Lord bless
Romans 14:11(KJV)
