Date: 12/13/2016 10:25 am
Date: 09/15/2019 12:38 pm
1978 Pinto Wagon V8
Date: 04/28/2023 03:26 pm
Date: 05/13/2021 05:29 pm
Date: 07/13/2018 02:21 pm
1974 Ford Pinto Runabout
Date: 07/10/2025 09:33 pm
Date: 10/24/2019 01:43 pm
Date: 04/15/2017 05:14 pm
13" Style Steel Trim Rings
Date: 10/09/2020 10:35 pm
  • Online today: 531
  • Guests: 179
  • Total: 179
Differemtial swap
Started by PhiLov80, March 07, 2014, 12:39:51 AM
Id like more info on this 8.8 swap from an explorer. i can get a good rearend from an explorer out of the pull you own parts yard for like $100 and it'd have disc brakes, 5 lugs and possibly a positrac already. The stock gears would be wrong for me, but could work still.
What needs to be done to make it fit a pinto? Does it need the axle tubes narrowed and new spring perches and shock mounts added or do i just use two short axle shafts in the existing tubes and change the spring perches and shock mounts?
tbucketjack
There is another posibility and thats a 7.5" out of a 90's Ford Ranger.
im running a 8.8...... i started with a disc rear end and it was too wide so i swapped in some fox mustang axles and drum brakes which narrowed it  1.5 inches... i run 15x8 rims with 5 inch backspacing and it all fits under the car.... if you want disc id go as suggested with a exploder rear end with one side shortened..... if you get it from a 4x4 you get 31 spline axles and either 373 or 410 gears from the factory....
The MII 8" rear does swap right in but you will either need custom axles or you can re-drill the stock axles to 5 lug. I have a set at a machine shop getting that done now.
There are guys with the 8.8 out of an Explorer that swap the long tube & axle out for another short side & run them. A 67-ish Mustang 8" comes 5-lug & is only 1 1/2" wider & swaps in by simply welding on spring pads. I picked one up for $100 complete.
PhiLov80
I am modifying an 80 Pinto cruiser wagon. 87 turbo fuel injected motor, totally blue printed, balanced, big valves, 5-speed. Purchased an 8.8 disc brake posi that will have to be narrowed to make it work. Is there a simpler solution? I've read an 8" Mustang II will bolt in without narrowing. However I've yet to find one with 5-lug disc. Any suggestions?
