Date: 04/12/2017 08:15 am
Looking for a 1980 windshield
Date: 07/30/2020 04:51 pm
Date: 07/21/2017 11:49 am
77 Cruising Wagon Front Seats
Date: 04/12/2017 12:37 pm
95 2.3l short block
Date: 03/18/2017 04:54 pm
79-80 full glass hatch
Date: 01/04/2017 04:04 am
Date: 04/20/2017 10:10 am
Date: 12/10/2016 04:11 pm
Date: 09/26/2019 05:31 pm
  • Online today: 587
  • Guests: 284
  • Total: 284
Pinto brake swap question
Started by pintopatty, February 22, 2014, 07:20:44 PM
Looking at the parts catalogs and Ford manuals, it looks like the late models use the larger cylinder that was used on the early station wagons.  These larger cylinders also have a larger thread size.
71-73 rear wheel cylinders differ from 74-up versions & carry different part numbers. I found a pair of NOS wheel cylinders for my 71 for $40 so I bought them but haven't installed them yet so I'm not sure of all the differences but I do know there are some.
pintopatty
Thanks for the info and the links
bbobcat75
The axles are different from a 73 to a 78!! Found out the hard way! The mounts rhhild the axles in, bolt holes are in different spots! Good luck
1975 mercury bobcat 2.8 auto
RockAuto and NAPA both offer replacement cylinders, see links.  Get the cylinders for rear with a 23/32" bore (7/8" is for the station wagon rear, 1" is for the front).
http://www.rockauto.com/     enter vehicle info
http://www.napaonline.com/Catalog/Result.aspx/Ford-Pinto-1972/_/Ntt-/Ntk-Keyword/Nty-1/Ne-25000/N-599001%20101972%2050026%202026028%2026417%20500011%20500999
FYI, the 74-80 rears have a larger hub than the 71-72 models (not sure about 73's).  If you are using the stock 1972 steel wheels that use the center hole for location, they will not fit over the larger hub of the 74-80 axle.  I suspect you could swap axles and drums, but have not tried it.
pintopatty
I just bought a 72 Pinto trunk car that needs some brake work. Ive had some trouble finding the rear wheel cylinders for the 72. I found a 79/80 model Pinto in a local salvage yard it has power brakes that I thought about swapping into the 72 along with the rear end. So will the booster bolt into the 72 and is there any benefit from the later rear end? Thanks for any help
