Date: 08/03/2018 09:19 am
Date: 06/22/2017 07:19 am
71-71 speedo cable
Date: 07/31/2021 09:04 pm
Need seals Pinto Wagon
Date: 02/16/2017 05:09 pm
Wanted 71-73 Pinto grill
Date: 03/09/2019 10:45 pm
72 Pinto Wagon for sale
Date: 12/31/2017 08:40 pm
2.3 front sump oil pan
Date: 07/24/2018 03:17 pm
Date: 10/03/2018 02:00 pm
  • Online today: 452
  • Guests: 243
  • Total: 243
Cracked Steering Wheel
Started by D1, February 18, 2014, 08:37:08 PM
dianne
So it's best to just find replacement steering wheels I guess...
Vehicles:
- 1976 Mustang II mini-stock
- 1978 Mustang King Cobra II
- 1979 Ford Pinto Runabout
- 1986 Chevy K5 Blazer
- 1997 Suzuki Marauder
Plastic always continues to give off any VOC in  it as it heats, just like rubber. What that means is that any crack fixed will probably just have another one as its' friend later. I've seen wheels with 3-4 cracks in them, as the plastic shrinks it has a tendency to try to even stress all along the length of it.
You can get out much cheaper than the kit by simply using epoxy yourself, sanding it smooth and then repainting wheel with epoxy paint to lessen wear on it. Don't be surprised if the epoxy (yours or the stuff used in the kit) cracks loose later itself, the two materials are different and cannot be expected to stay joined forever, heat will tell the tale there. The joint will last longer if you can rough up the plastic edge a bit for some tooth so the epoxy holds better, say using a thin nail file or something similar.
I personally loathe 'kits' of stuff, preferring to research and then buy only the basics needed, you usually save at least 50% doing that.
dianne
Vehicles:
Search the web for plastic steering wheel repair. It can be done then painted to match but time & cost is a factor. Swapping the wheel is an easy job so I'd look for a nice replacement instead.
dianne
Great question, other than a cover or replacement can a steering wheel be repaired? Not redipped, but repaired?
Vehicles:
Grant steering wheel cover............................
D1
Anyone ever used one of the DIY kits to repair a cracked steering wheel?
or any suggestions as to the best way to fix the cracks?
Thanks
May the Lord bless
Romans 14:11(KJV)
