78 wagon instrument y
Date: 04/30/2018 07:41 pm
Date: 11/05/2020 06:32 pm
Date: 02/08/2018 02:26 pm
1980 Ford Pinto For Sale
Date: 07/01/2018 03:21 pm
74 Pinto Rear Side Lights
Date: 02/18/2017 05:47 pm
Date: 02/04/2018 08:26 am
1971 Pinto
Date: 03/04/2017 11:28 pm
'80 Pinto Wagon
Date: 02/01/2018 05:20 pm
postal pinto
Date: 06/03/2020 09:31 am
  • Online today: 529
  • Guests: 478
  • Total: 478
DIS 2.3 Swap - Check engine light and codes present
Started by pintoguy76, January 31, 2014, 11:30:01 PM
It appears the EGR Position sensor was the problem. I replaced it and  there is no more check engine light :)
Haven't totally verified it yet, but I believe the EGR Valve Position sensor was the problem. I changed it and then drove it all day after replacing that part with no more engine light coming on....
So. That may take care of all the codes. The 114 ACT code might just be due to running a KOEO test on a cold engine....
The EGR codes at least could be from the 558, the others may result from that, PCM detects it has sent voltage to solenoid, but result coming back not what it expects (the other two codes). I'd verify that solenoid works and power to it.
Ok. Codes cleared. Engine was not warmed up the first time so I think that the 116 code was due to that.
However, now we have code 114 as well as 558, 332, and 334. The rest of the  codes are gone.
114 Air charge temperature sensor higher or lower than expected voltage.
558 EGR valve regulator solenoid circuit fault
332 Insufficient EGR flow detected
334 EGR closed valve voltage high
RSM
I'd start by clearing the codes. That gives you a clean slate and a better starting point. Then run the car thru the paces and see what shows up.
OK heres whats going on. I have a 91 mustang 2.3 DIS in my 74 wagon. It starts and runs good except for a couple minor glitches here and there. For example, if the engine is at idle or low RPM.... in gear.... and I floor the throttle, it will buck and jerk like an angry bull at a rodeo. Any other time its fine. I can floor it as long as it isnt near idle when I do it.
Also after driving for a while the check engine light comes on, and the engine begins to stumble and loose power. After a few seconds it clears up but the check engine light stays on until i shut the car off. Then its the same thing again after a bit.
Not really sure what the deal is. Here are the codes and what my book says is the problem. Key on, engine off.
116 Engine coolant temperature higher or lower than expected
172 Heated exhaust gas oxygen sensor fault/lean
173 Heated exhaust gas oxygen sensor fault/rich
186 Fault in injector pulse width circuit/high
223 Loss of dual plug inhibit control
224 Erratic IDM output to processor
Note: I have not yet cleared the codes. The ignition module was replaced a while back, and the oxygen sensor was replaced just yesterday. The car is not driven much, so it is possible some of these codes could be old, but I am not sure.
Can anyone help?
