Date: 02/18/2017 04:41 pm
Date: 01/23/2017 07:41 am
Date: 04/07/2021 06:12 pm
Electrical
Date: 03/29/2017 11:37 am
Pinto Watch
Date: 06/22/2019 07:12 pm
1600 CC WATER PUMP
Date: 06/02/2018 09:13 am
ford pinto door panels
Date: 03/20/2022 07:51 pm
Need Brakes for 1971 Pinto
Date: 04/27/2018 11:48 pm
Date: 07/20/2017 01:23 am
  • Online today: 535
  • Guests: 410
  • Total: 410
2.3 Weak/No Spark While Cranking When Damp Outside
Started by Chopchop, January 13, 2014, 08:16:13 AM
Chopchop
Awesome, thanks for the great tips!
It was 20* outside, I went out and both cars fired right up like nobody's business.
I pulled the cap on the '81 - oddly, written on the outside of the cap in black magic marker was, "Must be grey in color."
Okay....
The cap looked fine and the inside was bone dry with no bad-looking stuff anywhere.  I cleaned the contacts with a small wire brush, sprayed it down with WD-40, wiped it off and cleaned the rotor as well (it looked just fine).
I put the cap back on and it started with no issues which was no surprise because it's always started after it's warmed up.
I checked voltage at the coil and when running it was 8.94-ish.
I turned the car off, turned the ignition on and connected my remote start switch to the solenoid and the positive cable of the battery, hit the button and......no start.  It'd crank just fine but it wouldn't start.
I hit the key and it fired right up.
I did this a few times and the engine won't start unless I use the key - except for one time.
Just when I let off the remote start button, it caught and fired up but somehow, somewhere, there's got to be a circuit that's completed when you crank the engine with the key that's NOT completed when you just put power to the solenoid.
So, at least I know that trying to start it with the remote start button connected the way it's connected isn't going to work for me.
Next question - where do I connect the remote start button's leads to allow me to start the car with the ignition switch in the "Run" position?
I think this will lead me to the problem.  I think that whatever circuit is completed via the ignition switch being turned to the "Start/Crank" position isn't being completed when it's damp.  I dunno why, I dunno how but I'm thinking that's where the issue lies.....
Also, I don't know if I mentioned it but the coils and ignition modules are new as well.  I cleaned all leads and connectors before connecting them.
Thanks again for everybody's ideas here!
Dave
Most likely ignition. Condensation in cap or humidity alone, you may not see it. Bad wires that jump outside thru insulation in humidity, they are old even if no mileage. Possible coil spark jumping at top tower.
Make sure dist rotor is bent up to positively contact the carbon in cap, make sure that carbon point is there and not broken. Clean rotor outside tip off of carbon to bare like new. Look for ANY cracks in cap or giveaway carbon tracking inside it. Pull plugs and look for tracking around the outsides of the porcelain, common to jump there and not internally like supposed to. Check for corrosion inside any plug wire snap-ons.
Coil if only slightly shorted internally can be slightly weak and just not start in your conditions but would be odd for two cars to do that exactly the same. Would be odd to be module as well but not impossible as noted here already. Pull module connector and check for corrosion there as well.
Battery connections can come in to play as well, humidity can sap power going across substandard connections. Will seem to start fine but the slight loss saps the amount the electronic ignition needs since the starter sucks up most of the current.
Look at the color of the spark when your cranking it over. If its more white than blue your coil it bad even though you get spark. The stock ignition is a very good one and needs nothing aftermarket added on to it. Stay Ford and you'll stay ok.
jtowndown
If the wd-40 does not work, check for spark at ignition coil  if you have strong spark i would change the wires/rotor button/distributor cap.
slowride
I had a similar issue with mine. What happened was, as the temp dropped the PC board inside the ignition module would contract. There was a break in the board that would make contact when warmer (expanded), but would become an open circuit as the temp dropped. Replaced the module and life has been good......
WELCOME  Chopchop!
Dwayne :)
Like Art, my first thought was moisture in the distributor cap.  Had a similar problem years ago.  Hope your fix is that simple!
No, all you do is crank the motor(bypassing key) that won't effect anything else, unless the battery is weak then it takes all the power to crank the motor and not have enough to feed the ignition, but you mentioned new batteries so that shouldn't be an issue. You might check the resistance in your plug wires too?..
Chopchop
Oh, I'd love it if it was an easy fix like that.     :)
I'll pull everything apart, clean it and wipe everything down in hopes that your method will work for me.
Thank you very much for taking the time to try to help me out.  I very much appreciate it and will post back here if I find anything interesting or suspect.
One other thing that I failed to mention - because I work alone, I'm using a remote start button to crank the engines and check for spark.  I attach one lead to the starter solenoid and the other to the positive cable of the battery.  I leave the ignition switch in the "run" position and stick my head under the hood before I hit the button.  That's the only way I can check for spark.
I wonder if there is a circuit that is not completing because my method does not allow the ignition switch to turn to the "start" position?
Thanks again!
Dave
Welcome to the site Dave! I had that very same problem before every time it rained or a damp day wouldn't start drove me nuts for a while, come to find out it was moisture in the cap, wiped it down with WD and end of problem, not saying that is your issue just my experience but might want to check for that the next time it don't want to start.
Chopchop
Hi
My name is Dave.  I'm new to this forum and this is my first post.  I'm hoping (praying) that someone here will be able to help me with this because I'm losing what little is left of my mind trying to figure it out.
First, I have a 76 Pinto with the 2.3 and I have a 1981-ish Shay Thunderbird (factory built 1955 T-Bird replica sold new through the Ford dealers) with a 2.3 / 4 speed.
Right now I'm focusing on the 1981  2.3 but the 1976 2.3 appears to have the same problem.
The Problem:
Neither of these engines will start when it's wet / damp outside.  They will fire first time, every time when the weather is hot or cold or anything other than when it's wet.  If the engine's been running for a while and warmed up, both engines will fire up without issue.
Last week it was in the minus temperatures and both cars fired right up.  When the temperatures climbed to the high 30's and the weather turned wet, they would NOT start.  I've consistently had this problem.
- Both cars have new batteries with very good cranking power, new coils and new -ignition modules.
- Both cars run like brand new when the weather isn't wet.
- My '81  2.3 is bone dry under the hood but the '76 has a lot of under-hood condensation (despite being stored in a completely covered car port).
- When running, the spark on #1 cylinder is perfect.
- When cranking, I usually get one good spark on #1 cylinder as soon as I hit the key then after a 1/2 a second the spark turns either very weak or there's no spark at all.  The same is true for #4 cylinder.
- I have electric fuel pumps on both cars and I can see and smell fuel at the carbs.
The weak or no spark problem seems to be ONLY when cranking.
- If I can get the engines to run, my in-line spark plug tester shows a GREAT looking spark on #1 cylinder.
I fully believe this is a spark/ignition problem and not a fuel problem and I am hoping someone here can help me out with this.
Also, both engines are extremely low mileage.  The '76 has only 15K and the '81 has 25K -- they are both very original engines and in fact, the lowest mileage cars I've ever owned!
Thanks in advance for any help anyone can give me with this problem.
Thank you,
Dave
