  • Online today: 587
  • Guests: 307
  • Total: 307
1979 mercury bobcat uneven idle
Started by jtowndown, December 29, 2013, 08:04:48 PM
jtowndown
trust me i have used more than 1 can of wd-40 /starter fluid looking hoping it was a vacuum leak.
Quote from: dick1172762 on January 02, 2014, 06:38:23 PM
Spray WD40 all around every gasket you can get to with the engine running. If the RPM goes up and then back down, you've found the leak. WD40 burns almost as good as gas and will be sucked in at the leak. If the modulator is leaking you will be able to stay in low till the engine blows if the shifter is in low. Old dirt cheap drag race trick.
jtowndown
My problem is that i had lymphoma right after i rebuilt the engine and put it in. I had a laundry list of stuff to do, but after an year and a lot of weed my memory is a little foggy. I know i rushed putting it back together because I was excited about my first rebuild.
You can get springs in different tensions depends on what kind of curve you want(trial and error)but if you have a broken spring timing will be all over the place.
jtowndown
I have been wondering about the sticky glue like substance on my drivers side fender. I stumble into the answer by reading some of the forums on here I'm thinking its epoxy from the ICM. A new one is on the way with a new distributor, wires, cap, rotor. I got an new distributor because I was reading about the weights  on distributor having a loose spring. Since I have no idea what the spring tension should be on the weights i got a new one. Im sure its ready for a new one since the old one says ford on it.
jtowndown
my car idles at 1200 rpm but when i put it in drive it drops down to 900 rpm is this common a 300 rpm drop
Looks like an old school Sun tach?, gotta be worth 20hp at least, LOL.. ;D ;D
jtowndown
jtowndown
I had to put the gasket on here to give you something to laugh at. I will buy a gasket cutter set from the snap-on man. The gasket was made out of a folder. I have changed carb airhorn gasket, both carburetor and spacer gasket. changed plugs Going to check compression, timing when i can. but i did add 15 hp with my tach
I'd say it's due for a new gasket, LOL...
I make my own gaskets as well but they look substantially better than that hack job.
Compression test should be first thing you do on an old motor like these to save lots of wasted effort, the vacuum gauge jerking that rapidly says something wrong there.
Maybe a vacuum leak. On 2.3s occasionally the intake gasket sucks a hole in the bottom of one of the runners where can't be seen to leak.
jtowndown
you know your life sucks when!
jtowndown
all right i will get all results to you guys
Ok, first put on your new parts and check everything you mentioned and try it and let us know the results and we'll go from there.
jtowndown
My bobcat's engine shakes at idle. At higher rpm it runs like a sewing machine. If i put it in drive it runs better. I noticed that the carburetor to egr spacer gasket is about 3/4 of an inch and looks like its made of cotton or fiberglass.  I have bought a new one going to put it on tomorrow. I have blocked the egr valve off and welded the hole in the exhaust manifold. I have ordered a Stop throttle solenoid. (its missing on my car). The carb is also missing the fast idle valve screw. I am going to see if some sort of machine screw will fit and use a nut to lock the adjustment. It seems like I can't get my car to idle down at all though I do not have a tachometer so i don't know. I have tried to adjust idle, mixture screw, and ignition timing. I put a vacuum gauge on intake manifold at idle its jumping 15-18 in/Hg very fast like a vibration ( i think due to a lean miss).At higher Rpm's its running at 22 in/Hg. Car is hard to start like its not getting enough fuel, I have to pump the crap out of the accelerator. I'm going to check motor mounts (for shaking), Check spark plugs for lean/rich condition, compression test (for giggles) The transmission vacuum modulator to see if hose came off, replace carb gasket, check/clean jets, check float height, and replace fast idle valve screw. I don't have a power booster, and the Its federal emissions with the 5200 v2 carb, automatic transmission. Is it worth removing canister, or leave it alone. If You guys have any ideas of other things to check, replace, or problems with my spelling or grammar(lol). Leave a comment  they will be used and Much appreciated :) :D ;)
