Date: 08/09/2018 07:49 am
turbo 4 cyl and aod trans
Date: 12/14/2019 04:55 pm
Date: 04/21/2017 02:03 pm
1973 Pinto hatchback for sale
Date: 11/13/2023 11:30 am
Date: 08/20/2017 01:34 pm
Date: 07/13/2018 02:21 pm
Date: 07/10/2016 10:17 am
Wanted early pinto
Date: 10/03/2019 02:42 pm
Date: 07/17/2019 05:23 pm
  • Online today: 535
  • Guests: 501
  • Total: 501
Fresh Motor Won't Start.
Started by From_Jonah, December 14, 2013, 07:17:10 PM
Quote from: amc49 on December 17, 2013, 01:40:28 AM
Doesn't matter where distributor ends up at as long as you have swing both ways to change timing and all parts like cap screws easy to get to. Rotor needs to be pointed at #1 and with crank on TDC but at the CORRECT TDC, there are two. One is at overlap and the other is at top of compression stroke, you need the second one or distributor 180 out like mentioned before.
You can use any post you want for #1 as long as the ones following are in the correct firing order.
What he said!..
From_Jonah
First off, thanks for all the help everyone! I think I'm moving in the right direction anyway.
So here's the two 2300 diagrams I have in my Chiltons book. The tabs on my distributor are like the one that it shows for 1974, but my car is an 80 model.
easiest way to time these motors is set the crank to TDC and then use the string method http://www.turbotbird.com/techinfo/CamTiming/Cam%20Timing%20Belt%20Replacement%20and%20Set%20Up.htm
Once your sure the belts on perfect then drop your dizzy in to the correct spot and install your wires and you should be GTG.
If it doesn't start after that get a compression tester and see if you have a valve open or not opening. But it sounds like yah got the timing off sometimes setting the timing can be a pain if using the stock markings.
Distributor is 180* out. Firing order is the same for all 2.3 engines, so I'm not sure what you mean by changing the wire position to an '80 model vs. a '74.
'I think there is a specific way to set the lifters up on these motors. Can't recall what it is cause mine is solid lifter, but think if it isn't done valves will not fully close= no compression.
Correct, the check gets done if you ground valves or moved them around. Commonly undone in the old days and gave guys with new motors pure fits.
Used to be a number Ford gave to check valve clearance on 2.3 with hydraulic lifters, collapse lifter and then fit valve in hole with a follower and that clearance then gets measured between base of cam lobe and follower. It guarantees the working assembly is in the middle of the hydraulic travel of lifter for very long life. If valve now ends up being too long after the machine work the lifter runs out of internal adjustment travel while shrinking in height and holds valve open. Needless to say engine not gonna run very well if at all like that. I heard of guys doing that all through the '70s, then they invariably blamed the engine for being a crap motor and where a lot of anti-2.3 BS came from back then. People with no sense.
Here we go, I found the number, called 'collapsed lifter gap' in '80 Ford service manual and on 2.3 with hydro lifters, .040"-.050". The clearance puts the lifter seat right about in the middle of its' travel or I'm thinking around .080" total travel there. It guarantees the valves will be closed at proper time.
'74 is a point distributor, and asking for start up issues there. The points have to be set correct gap or no coil dwell and your exact issue. If you have '79 or 80 distributor and the box for it miles ahead using it. All those years distributor position and plug wiring the same.
Something is definitely out of time, I would just start over and make sure everything is right and save a lot of guess work.
Clydesdale80
by "V" on the cam he means the V-shape formed by the two cam lobes for cylinder #1.  The V-shape should be right side up when crank is at TDC.  If the V is upside down, your cam timing is 180 degrees off
From_Jonah
I tried retarding the timing a bit and now it's backfiring a lot.
From_Jonah
Also, what do you mean about the V on the cam being up?
From_Jonah
I do have spark. I had a little confusion and still do about my distributor though. According to my Chiltons manual, I have the 74 model distributor in my car but my car is an 80. I had the plug wires plugged in like a 74, so this morning I changed it to like the 80 model and it's trying to start but only for just a second. And when it does it shoots huge flames out the tailpipe.
rramjet
D.R.Ball
Spark plug wiring correct ? Have you tested the duraspark module etc....Are you sure the crank is timed correctly . Have you removed the spark plug number 1 and used a dowel to check to see if the crank is really at top dead center. And finally is the cam on number 1 have a V up or is it down. The V should be up on number one....
Did you pull a plug wire and check to see if you have spark??..
From_Jonah
So I just rebuilt the 2.3 in the wagon. Everything is torqued right, as far as I can tell, the timing is right on the cam, crank and aux. The distributor rotor is in the right place. It's firing. And I can't get the thing to start. I can't even get it to try. It'll turn over and I've poured some gas in the carb but it just won't start.
Anyone have any ideas on something I could be missing or something I'm getting wrong?
