Date: 01/20/2018 07:51 pm
Date: 12/31/2017 11:14 pm
1980 Pinto taillights
Date: 12/26/2017 03:48 pm
Front Body parts needed
Date: 02/09/2018 06:09 pm
Mustang II V8 swap parts
Date: 03/26/2017 02:25 pm
Date: 08/22/2017 09:21 pm
Date: 03/25/2019 09:02 pm
1976 Ford Pinto Pony
Date: 09/06/2018 05:40 pm
  • Online today: 583
  • Guests: 270
  • Total: 270
Not trying to reinvent the wheel
Started by slowride, December 12, 2013, 03:33:08 PM
Play in the actual cross joint or the pinchpoint? I have taken like hacksaw or dremel with a cutting wheel to open slot up for more pinch. Put joint in vise and pinch gap shut with no bolt in it to close the gap then dremel or hacksaw out the slot again to make more pinch grip ability. The wider slot then pinches in slightly more to positively lock solid as a rock.
That should be it but I'd take a look at what I have
slowride
Searched the forum for answers, but came up with nothing so figured I'd ask and see if anyone has been down this road before. I replaced the rag joint and rack assy on the '74 and it works well except for 1 annoying thing. The pinch bolt on the rack coupler tightens down but leaves just a hint of play. Rather than try to find a new coupler, I'm looking to upgrade it. Since the pinto/MII manual racks are used in quite a few different applications, there are a ton to 9/16-26 couplers available. It's the OTHER end I'm curious about. It LOOKS like a 1" DD shaft that makes up the bottom end of the intermediate shaft, but I haven't torn it down yet to check. Anyone know what the bottom end of the shaft is?
