Date: 12/09/2016 08:34 am
Date: 01/04/2017 04:07 am
need 1978 pinto guage cluster
Date: 03/07/2021 07:35 am
2.0 Cyl Head1973
Date: 11/29/2018 12:51 pm
Date: 05/15/2022 11:36 am
Date: 08/30/2021 03:20 pm
1978 ford pinto carb
Date: 02/04/2018 06:09 pm
1973 Interior parts wanted
Date: 01/02/2017 11:02 pm
Date: 08/01/2018 01:17 pm
  • Online today: 656
  • Guests: 574
  • Total: 574
the speedometer is acting up
Started by Red Beauty, December 11, 2013, 10:58:23 PM
As long as no one has been inside the unit to screw around with the flywheel return spring there is really very little to disintegrate........
jeremysdad
Quote from: Red Beauty on December 12, 2013, 12:56:52 PM
How do Ilube the cable?
Thanks for your help guys!
I use lithium (spray can), but you have to remove the cable from the back of the cluster. What year model is this? The later models have a reputation for disintegrated rear cluster housings. 75 and up, I believe? When I did mine, I followed the instructions (loosely) from my since disappearing Chilton's manual. Hopefully someone can give you better directions, it was the summer of 2012 when I did mine. lol
Yes, chatter when hand spinning the head is a dead giveaway.
Red Beauty
Generally the reason the needle bounces is because the cable is lacking lube.  It will bind in the sheathing until enough torque has built up that it snaps a few quick rotations and then bind again. That is what causes the needle bounce.
Like AMC 49 has stated the bushing in the speedometer itself can dry out. Usually in that case there is a chatter sound from speedometer
If that doesn't work, then the gauge head itself can be dry of lube. I have made up a fixture before to use on motorcycle and car that uses rubber hose and grease gun to clamp onto the outside of the gauge unit and when sealed you carefully pump a SMALL amount of grease in to lube the bushing right at end of gauge. Done correctly the gauge will go to working perfect and for years.
If you pump in too much to foul the flyball magnet you have screwed up. Just a LITTLE.
Quick way to test if the gauge? Grab the input stem that sticks out and spin it by flipping it with fingers while watching needle, if the needle moves jerky the head bushing is dry.
Red Beauty
Well thank you, Dwayne. :-)
I'll try that.
William
My wife had a Ford Tempo 20+ years ago that did that about every twelve months... she'd have the speedometer cable lubricated with graphite and that always took care of the problem.
Dwayne :)
Red Beauty
The speedometer is acting up! It acts OK sometimes though it bounces around + or - 5 mph. Other times it reads 30 mph too high? What does this mean? What am I to do? How do I do it!? Thanks guys. I appreciate any help I can get.
