Pinto Watch
Date: 06/22/2019 07:12 pm
2.8 radiator
Date: 10/25/2019 04:10 pm
Early 2.0 engines
Date: 05/09/2018 12:45 pm
Seeking parts
Date: 10/18/2020 10:35 am
2.3 pinto carb
Date: 08/18/2018 02:07 pm
79 pinto small parts
Date: 04/24/2019 03:16 pm
Date: 01/20/2018 07:51 pm
1973 Pangra
Date: 01/06/2015 02:19 pm
Date: 01/18/2017 05:35 pm
  • Online today: 500
  • Guests: 428
  • Total: 428
My parking break does not work
Started by Red Beauty, December 11, 2013, 08:04:10 PM
waldo786
I have a similar problem, although mine seems to be hard to pull up and the lever goes back down without it seeming to do anything.  I do plan on having it checked out but have no idea what is wrong.
It might also be the brake hardware on the drums. A good way to check is jack the car up, use jack stands to support the rear end and remove one wheel and drum. Get a good manual and see if everything is there, on that side, and than, of course check the other side. I'm betting it's not the cable but the hardware that makes everything work..  I have had to replace the hardware on two cars. If you get a brake hardware kit you should have every thing you need to fix the problem, just the hardware nothing else IE no brake shoes , cylinder etc...
Red Beauty
Jerry merrill
Look under the car below the brake handle area above the drive shaft to see if the cable is connected to the horseshoe  shaped bracket attached to the brake mechanism.
Red Beauty
Thank you for responding DBSS1234! I apreciate your response.
When I lift the handle it is as if no cable is attached to it. How do I see if that is the case or not. What kind of work needs to be done and where do I look?
Thanks again.
DBSS1234
The parking brake on the Pinto is cable accuated. Lifting the lever pulls on a cable which in turn pulls on a lever expanding the rear brake shoes. Most likley your problem is a rusted brake cable. This happens when the parking brake is not used very often, very comon on automatic transmission cars as most people just put in park and not engage the parking brake.To be safe replace it with a new one.
Red Beauty
The parking break on my 77 pinto wagon will not ingage. Is it a cable? How do I fix it? I am new in the world of ford pinto mechanics and am eager to learn. There's not much info online though that I can find. Not to mention I am relatively new to auto mechanics in general.
Can any one help!?
Thanks
-William
