Date: 12/26/2016 04:29 pm
1980 Pinto Wagon
Date: 02/29/2020 07:01 pm
1977 Pinto Cruizin Wagon
Date: 08/07/2023 02:52 pm
convert to stick
Date: 05/19/2018 09:26 pm
Front sump oil pan
Date: 01/02/2017 06:54 pm
Date: 08/08/2017 01:44 pm
Early 2.0 engines
Date: 05/09/2018 12:45 pm
Date: 02/28/2024 02:07 pm
Built 2.0
Date: 10/07/2018 05:27 pm
  • Online today: 489
  • Guests: 166
  • Total: 166
1977 V6 drive shaft color codes
Started by DBSS1234, December 11, 2013, 03:06:45 PM
DBSS1234
Looking at my build sheet it appears the stripe colors will be blue, green, green, green. With this info I should only need the stripe dimensions, a drive shaft from a 4 cylinder Pinto should work as I doubt the dimensions and location of the stripes would change only the colors.
Thanks again.
DBSS1234
Those of you that have seen my posts of the restoration of my crusing wagon know I am trying to replicate the factory right down to the correct markings and color codes. Ford used a color code on their driveshafts to aid the assembly line workers. My drive shaft was too heavily corroded to find the stripes. Can any 1977 V6 Pinto wagon owners out there check for painted stripes on their drive shafts? I would need dimensions of the stripe widths, locations, and colors. Pictures would help too.
Thanks!
