Two 1978 Pinto Station Wagons
Date: 05/18/2025 03:10 pm
Date: 07/01/2019 03:17 pm
Date: 09/01/2017 07:52 am
Oil pan front sump style
Date: 01/10/2017 09:19 am
Drip rail chrome
Date: 01/14/2017 09:18 am
1973 Pinto hatchback for sale
Date: 11/13/2023 11:30 am
Date: 06/25/2021 12:59 am
Parting out 77 Bobcat Hatch
Date: 11/06/2017 04:16 pm
2.3 pinto carb
Date: 08/18/2018 02:07 pm
  • Online today: 583
  • Guests: 375
  • Total: 375
Fuel Line Placement
Started by From_Jonah, December 07, 2013, 02:19:18 PM
From_Jonah
That's awesome. That article helps me a ton. Timing confuses me but that clears it up a lot.
There's no mark on the aux gear(at least mine don't have one)at TDC the rotor on the distributor needs to be lined up with #1 plug wire.
Clydesdale80
I believe the aux. marker goes straight up
Bought a 1978 hatchback to be my first car.
From_Jonah
Okay awesome! Do I line up the aux pointer with the string too?
Clydesdale80
do you have timing belt cover and pointer or not?  if so, line up the mark on the cam gear with the pointer while the crank is at TDC. If you don't have a pointer, use a string to make a straight line between the center of the cam gear and the center of the auxiliary gear.  line up the mark on the cam gear with the string while the crank is at TDC
From_Jonah
Also, I think my belt timing is off. I have a hard time understanding timing, and where my sprockets need to go and such so any help in that area would be super greatly appreciated.
From_Jonah
So, I'm almost done with the engine rebuild in my '80. I've got the motor back in the car and almost everything is hooked up but I've lost the pictures I had of where the fuel lines run and one of them broke when I was re installing the motor.
Could someone possibly either take pictures or send me a diagram of where the line go?
Thanks!
