1973 Pinto hatchback for sale
Date: 11/13/2023 11:30 am
Pinto wagon Parts
Date: 06/23/2021 03:25 pm
parts needed
Date: 02/20/2017 07:58 am
Misc pinto parts 71-73 2.0
Date: 05/05/2020 11:56 pm
2.3 pinto carb
Date: 08/18/2018 02:07 pm
72 PINTO WAGON
Date: 09/23/2018 06:16 pm
Date: 02/26/2017 03:22 pm
Front Body parts needed
Date: 02/09/2018 06:09 pm
Date: 04/10/2017 07:30 pm
  • Online today: 1,166
  • Guests: 1098
  • Total: 1098
Performance trick: Advancing the cam one tooth on the timing belt?????
Started by gaeliccouple, November 08, 2013, 02:49:34 PM
Crazy Lacy
I noticed my 2.0 1971 Pinto was a tooth off when I  was tinker with it, So I set the belt right. power seems about the same. ???
Join my - Pinto Ford USA - on Face Book.
William "Crazy Lacy" Furmage
Original Vans BMX Freestyle Pioneer 1982
Pipe plug that size requires a bigger hole. I've drilled them out for a tap, but that's work. Driving in a plug is EASY.
Don't have drill index handy but that hole size says probably very easy to tap hole for a 1/4" hole to simply screw in a like allen setscrew glued with silicone and removeable if necessary.
Yeah, should be a quick fix guess I'll start looking for a header.
Best I can recall, is the ports are .223 dia. Easy if you have a lathe. Metric I'm sure. Go for it.
I'm guessing they would be metric maybe?, guess just about any round stock will work though just throw it up in the lathe and turn it down to size, I done away with all that smog crap already, only thing left is the EGR plate which I'm gonna make an adapter to replace it.
Finding the right size might be hard. Every hardware store I was ever in, had what was called, drill rod in ever size known. You might have to file it down, but you only need a piece 2" long. File it to fit, drive it in, cut off what sticks out and your done. They can't come out, and if they leak a little, they will fill up with carbon. The header gasket will seal them too. Use a gasket for a mid 80's Mustang 2.3L. It will cover the port too. This will get rid of the ERG too and help your gas mileage. Easy fix.
I was wondering if a press plug could be used, makes it easier yet.
Holes in the head are an easy fix. I've taped and screwed in pipe plugs, used ball bearings, and the easy way is too just drive a plug(not a spark plug) into the hole. Even a 1/4"deep is plenty because once the header is on, the plugs can't come out and they can't go in because of the way the hole is made. Easy fix because the manifold will be off to put on your new Ranger header. Way to go.
Quote from: dick1172762 on November 14, 2013, 03:03:11 PM
Look on craigslist, under parting out(cars & trucks). Atso look under Rangers(for sale). Look for ones with way to low a price, like $300. Some of those are junk or not running and will sell parts sometimes. Cheaper that way too.
Thanks, I'll give that a shot.
Quote from: bbobcat75 on November 14, 2013, 03:25:06 PM
FORD RANGER HEADERS WORK GREAT BUT PINTO HEADS NEED TO BE TAPPED AND FILL THE EGR PORTS OR YOU WILL HAVE A MAJOR EXHAUST LEAK!!
FOUND OUT THE HARD WAY THOUGHT MINE WHERE PLUGGED UP TILL I HIT 3RD GEAR ON THE ROAD!!!
GOOD LUCK DOING IT IN THE CAR WAY EASIER WITH HEAD OFF!!!
hanks, I'll make a note of that.
Quote from: dick1172762 on November 14, 2013, 01:26:14 PM
Ever junk yard has many. I'm saving the one I have left for my next Pinto(#17). One other thing is, the header really helps clean-up the clutter under the hood. Make sure the battery is shielded like it came from the factory. Ever stock, the battery will get hot with out the shield. I sand blast all my headers(Rangers), pant them with VHT, and bake them in the wife's oven at as high a temp it will go for 4 hours or so. They come out looking great and look even better when installed. After installing it, I fire the motor up and run or drive for 30"or so. Well worth the trouble. 2" pipe all the way out. You may not smoke the tires, but YOU will like it. If you do like I do, and run the pipe out in front of back tire, you can do it all at home and save big $$$$. 2"ID glass pack in the drive shaft tunnel and your done. Hope this helps.
Thanks Dick, not worried about smoking tires with this one wife's not into that,lol. I'll see if I can find one local not much for a junkyard here, I have the factory battery shield so problem there, should be an easy setup to build.
Quote from: dick1172762 on November 14, 2013, 09:46:49 AM
The junk yards around here(NW AR)are full of them. Who's going to buy them. Ranger owners already have them. That leaves us guys. I've won quite a few races in Autocross and Road Racing  with a Ranger header. Been the year end champ in both too. And you don't have to worry about dragging it on a lowered Pinto. I love them as you can tell. Every one needs to understand that a 2300 L motor is really a tractor motor, not 10000 rpm ricer. IT'S BUILT FOR TORQUE!!!! Nothing  else. Use it for that and you'll love it.
Hey Dick, you wouldn't happen to have an extra one laying around would ya??..
Quote from: 71pintoracer on November 13, 2013, 12:26:17 PM
All good and valid points Dick. I guess it's better than a cracked stock manifold for the weight savings if nothing else. But a header? Have you ever flow tested one? hahahahha! But I digress. I didn't realize they were so plentiful now. And cheap. :)
I was wondering about the dirt factor too, thought about cutting the top section off and keep the bottom for the pointer but I think I'll just leave it alone, does look better without it though.
I ran with no timing cover for a good while, after doing it longterm the pulleys will round off from dust wearing parts. If doing it again I would be using a cover, it helps seals last longer as well. It did make for questions though and looked neat. And could change a belt in maybe five minutes.
Thanks guys, looks like the Ranger header is the way to go then, this is the wife's car and all she cares about is mileage no hot rodding, be a miracle if rpm's reach 3000, lol..
Theirs not a thing wrong with a Ranger header!!!! First of all, their stainless steel, second of all, they FIT, third, their CHEAP, forth, they will out last the car. Only thing you need to do is remove the stands off  that allow Ford to use the same long bolts that the used on a cast iron manifold. Take them off and use short bolts. Looks much better! Most Pintos I've seen have WAY too big a pipe running off the header. Fine if you take it to 6000 rpm each time you shift, but no good when you leave a stop light at 1500 rpm. 2" pipe is all you need on a street driven Pinto. Cheap and many mufflers to pick from. And the junk yards are FULL of them at $30 to $50 each. Get the down pipe when you can, to use on your car. And best of all, you will not look and sound like a "RICER". And a Ranger header will fit in my wife's oven, so I can paint it with VHS and bake it at 400 degs to cure it. All in all, a winner!
Quote from: 71pintoracer on November 12, 2013, 05:31:50 PM
(sigh......) Spend your hard earned money on a crappy Ranger header.
I was thinking of the Ranger header heard they worked?, my stock manifold has a crack and I know it's gonna have to be replaced pretty soon, what would you recommend?.. Thanks..
Quote from: amc49 on November 11, 2013, 11:09:56 PM
If you have asymmetrical lobe timings that linked earlier post method will not work, it is really the backyard way anyway.
(sigh......) I tried to make it as clear as possible. Maybe I didn't. If you have a STOCK CAM, this will get your cam timing pretty damn close. If you have a PERFORMANCE CAM you should have used the cam card, dial indicator and degree wheel in the first place. The power gain from say a 2.3 automatic with a STOCK CAM that is 6* retarded to 2* advanced is unreal. Been there done that. Many times. The people that I've done this for are amazed. It's simple, easy, cheap & doesn't take much time to do. And you can FEEL THE DIFFERENCE. So if you are working in the backyard, give it a try. Or not. Spend your hard earned money on a crappy Ranger header (? yea right) expensive intakes and big carb that does nothing but run rich and cut your gas mileage in half. Whatever. I tried.
Quote from: Wittsend on November 12, 2013, 11:53:52 AM
"O so cool when "ricers" look under your hood, (just after you smoked them at the local autocross)."
I wonder in Japan if they call us "Wheaters" or "Corners?"  Just thinking.
Tom
Since you "smoked " 'em at an Autocross, I would think we're Just "Corners"  ???  Oh , the good old day's in the 80's Bay area pylon scene: Mike Stevens in his CSP Pinto was a real threat. And his Pro Solo launches were a work of Art. I hope he's still around and keeping compact Fords running.
Tom
Late model Rangers use both round tooth pulleys and belts. Plus they are wider and made out of better stuff. This is what all the smart racers use now. You have to use all the Ranger parts to make it work. And no, it will not fit under you stock timing cover! I guess you could use the Ranger cover maybe. Or no cover at all like I do. So much easy'r to work on and O so cool when "ricers" look under your hood, (just after you smoked them at the local autocross).
Didn't know they made them rounded mine are square, Gates always been the best and I probably should change mine out again because this one I got from the Zone will just not time right, but then again the tab and dampener could be off too, gonna have to find absolute TDC first and see where I'm at, guess I'll dig out an old spark plug and make a piston stop.
